Who here has done thier upper ball joints?
66nightMARE
97
Katy, Texas
Well im changing out the upper balljoints on my car (66 mustang). Well on the upper control arm there are four RIVETS holding the ball joint "plate" or whatever you want to call it to the upper control arm. How the **** do I break them? It says in the manual to use a chisel. Yeah freakin right. I got the heads off of 2 of them with a grinder. The other 2 are not accesible with a large tool. Need some ideas.
blue65coupe said:
That sucks. I thought '65 and '66 were the same. I have a '65 and the uppers just unbolt. The lowers are riveted in where you replace the whole lower control arm but the uppers just bolt in. Learn something new everyday!
65' and 66' are the same and both had rivets from the factory.
Yours has been replaced sometime in the past. The Mustang upper ball joint is a common wear part. Once the rivets are removed, they are replaced with 4 bolts and nuts.
This was one of the first things I did for my restoration, and was pretty intimidated beforehand. I found doing this isn't really a big deal afterall. With no experience, I drilled the each rivet out, used a chisel to punch the excess metal through that was stubborn, and away they went without any butchering of the holes.
...also, if you're lowering your a-arms or already have them done, now would be a good time to consider a negative-wedge kit...just a thought.
Because I'm also going to race my Mustang, have my arms lowered more than 1", and others (66nightMare) may use his car for something other than normal street use. Even on certain public roads, I still reap the benefits of such modifications...as I said, it was only a suggestion. That's why, and that's why it's not a waste of money in some (like my) cases.
Do yourself a favor and change the whole upper arm assembly. They don't cost much more than the ball joints themselves. New ones will be stronger, not having been subjected to 30-40 years of wear and tear. Changing them also get you new upper bushings too, sometimes it's easier to do the whole front end, instead of piece meal.
