How is the ride quality? Should i go with the pro kit instead? My car looks like a 4x4 so im going to lower it. i daily it so i need springs that wont feel to harsh. what other parts do u recommend . do i need caster/camber plates?
i have stock suspension with sportlines (half coil cut off all four). The rides not perfect but its not so annoying that you wanna rip em out and put new ones in. Looks sweet as hell though.
Wow that must have a coilover look being that low. I have sportlines on mine mated with KYB GR-2 shocks/struts, Hotchkis lower control arms, and full length subframe connectors. You'd think the ride would be rather harsh but its actually quite comfortable through most bumps. You just have to make sure you dodge pot holes or you're gonna be in trouble. It handles like an S2000 around corners though.
I had them on my previous 94 GT, and I like the look and the ride alot. I had them paired with prothane poly urethane spring isolators and tokico blue shocks & struts. I highly recommend them.
I have them on my 95, switched over from the pro kit. A little harsher but I like the sportlines more, I also installed steeda x2 ball joints without the spring spacer and left out the lower isolator on the front springs which gives my stang a raked look. Its lowered 2 3/4" in front 2" out back, I still need to get a bump steer kit, c/c plates and I also want to change the end links to shorter ones for the lower sway bar .
