  • 1994 - 1995 Specific Tech
Who here is running a supercharger with a stock block?
  • Thread starter Thread starter Pokageek
  • Start date Start date Oct 29, 2006
  • 3
First Prev 2 of 3 Next Last
Pops Fun
961
14
59
Cincinnati, Ohio
Oct 30, 2006
#21
  • Oct 30, 2006
  • #21
Hi
Stock block with forged internals. Had 10.1 compression.
http://forums.stangnet.com/showthread.php?t=605090&highlight=compression
347ci Stroker (Paul’s Auto Engr)<o></o>
Mac Shorty Header<o></o>
TFS TW Heads (ported)<o></o>
Steeda 19 <st1></st1><o></o>
Cobra Intake (ported) <o></o>
SCT MAF<o></o>
Power Pipe<o></o>
Vortech, SQ<o></o>
Ford 3.73 Gear<o></o>
42# injectors<o></o>
H&S 1.72 Roller Rockers<o></o>
MSD 6al<o></o>
Blaster coil<o></o>
Walbro 255 LPH<o></o>
T-rex inline fuel pump<o></o>
Aluminum Flywheel<o></o>
TF Girdle<o></o>
Eagle Forged crank<o></o>
HPM uppers and lowers<o></o>
Sub frame connectors<o></o>
Pops Fun
961
14
59
Cincinnati, Ohio
Oct 30, 2006
#22
  • Oct 30, 2006
  • #22
Sorry double post
T
tjh566
608
Northern Va
Oct 30, 2006
#23
  • Oct 30, 2006
  • #23
FlyBy763 said:
meeeeeeeeeee
How Many psi you running?:SNSign:
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Oct 30, 2006
#24
  • Oct 30, 2006
  • #24
Kenne Bell only offers the 2.2L for the 94/95 Mustangs now.
I've been over this same topic myself for a while, but have leaned more towards having my stock engine rebuilt into a 306 with a CHP kit and AFR heads. Then I'll throw on a new 2.2L KB and have a major tune done. This keeps me emissions legal too.
Only downside for me with the KB is the strut tower brace issue. No one seems to make one and I've only seen one SN95 with a KB and an STB. I've been told I'd have to get one custom made. I'm into handling and plan on more suspension upgrades, but I like what the KB brings to the table in a street car.
Anyone on here have a KB blower and a strut tower brace?
How many miles do you have Pokageek (or did I miss that)? I have over 155,000 miles and I not comfortable doing anything to the engine at this point. I'm going to have patience for another year and then go nuts.
Pokageek
2,767
MA, USA
Oct 30, 2006
#25
  • Oct 30, 2006
  • #25
Sure car nut. I have about 2000 miles on my engine. It is new. ARP rod bolts and arp on the heads too.
Car Nut
1,176
Oct 30, 2006
#26
  • Oct 30, 2006
  • #26
New engine?! Throw anything you want on it within reason. Finish with a proper tune and you're set.
Pokageek
2,767
MA, USA
Oct 30, 2006
#27
  • Oct 30, 2006
  • #27
Okeedoke.
BlackVert
5,589
9
98
Bethesda, MD
Oct 30, 2006
#28
  • Oct 30, 2006
  • #28
Geek, what cam do you have? that is also a factor in final dynamic (running) compression and whether boost is good with your combo or not.
VibrantRedGT said:
Piston rings on #5 and #8 will go before anything in the block. I ran 12psi on the stock block for awhile until the #8 ring came apart.
that is what happened to me ... #8
http://www.corral.net/forums/showthread.php?t=846877
there is another guy on this forum, kennebell i think, who also got one to fit.
FlyBy763
439
Palm Bay, FL
Oct 30, 2006
#29
  • Oct 30, 2006
  • #29
Factory 3.33 pulley, usually around 8 pounds. Sometimes less.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Oct 31, 2006
#30
  • Oct 31, 2006
  • #30
Pokageek said:
Thanks guys, good discussion. So y'all think that if the tune is there I will be good. Also add an intercooler?
Ok, so here is another question..those of you who are using the stock block for a 331/347 set up with a power adder... Isn't that pushing the limits of the block even more? or is there something about 331/347 that makes the block tougher? Thanks.
yes it is. when i ordered my motor from coast i just couldnt justify the extra $1800 for the dart block. so basically i have a rotating assembly capable of high rpm's and handling 850+ hp in a block that is almost certain to fail at just above half of that. as far as longevity of a stock block in a 500+ situation like mine, all you can do is keep the tune rich, the timing low, and the rpm's down. mind you i am only speaking from experiences i have read on hardcore since im a lazy bastard and my car has been sitting at 90% complete for 2 months now.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Oct 31, 2006
#31
  • Oct 31, 2006
  • #31
im certain aftermarket rings were used in your build so you are probably fine in that department. as was stated before though, make sure to keep the boost down due to the high c/r.
Pokageek
2,767
MA, USA
Oct 31, 2006
#32
  • Oct 31, 2006
  • #32
Thanks guys. They said I have a "B" cam but they said it has .510 lift so must be a version of the b-cam.
94CobraPace
907
Houston, Tx.
Oct 31, 2006
#33
  • Oct 31, 2006
  • #33
Meee toooo.. Keep detonation away with mild boost, under 10 to be safe & you should be fine.
Pokageek
2,767
MA, USA
Oct 31, 2006
#34
  • Oct 31, 2006
  • #34
Ok, but how much HP can I get with say 8pounds of boost?
T
turbogt
723
Montana
Nov 1, 2006
#35
  • Nov 1, 2006
  • #35
The high rpms are a stock block killer..
Pokageek
2,767
MA, USA
Nov 1, 2006
#36
  • Nov 1, 2006
  • #36
Why? I would like to know. Also, how much HP can you get with 6 or 9 psi AND can it bee tuned to keep the power at a lower RPM like 4500? Reason I ask is because with nirtous, you have to RETARD the timing which takes away HP and then bump up so there is a lower base starting point if yo uknow what I mean.
Car Nut
1,176
Nov 1, 2006
#37
  • Nov 1, 2006
  • #37
I would think keeping your RPM limit around 5500 or so would be just fine. I think the big concern is if you get intersted in the 6000+ range. That's where the stock block can present problems in certian situations when higher horsepower is involved.
SVT3183
180
S Jersey
Nov 1, 2006
#38
  • Nov 1, 2006
  • #38
me. my tune is crap so it's going to JD's for a new one on the 10th before i grenade it
slvrsn95
28
#39
  • Nov 1, 2006
  • #39
stocker here also with no problems yet but deffinately ready for more HP...saving for the DART...
rio95
829
Grand Rapids, MI
Nov 1, 2006
#40
  • Nov 1, 2006
  • #40
You must never have checked out turbomustangs.com
I have run 17 psi and always run at least 15 psi with a completely stock lower end. I have accidently hit 20 psi and nothing broke.
It's all in the tune.
  • 3
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
L
New here from Maine
  • lobster
  • Mar 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 5, 2026
lobster
L
Clearance
  • 1993mustang50
  • Apr 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
2000xp8
D
4.6 DOHC build.
  • Diffydoc
  • Oct 11, 2025
  • Other Auto Tech
Other Auto Tech Oct 11, 2025
General karthief
