  • 1994 - 1995 Specific Tech
Why Delete the EGR?
  • Thread starter Thread starter rude_life
  • Start date Start date Apr 22, 2005
rude_life
372
  • Apr 22, 2005
why would someone delete the EGR? i thought your car would run like crap without it
HISSIN50
34
129
Apr 23, 2005
  • Apr 23, 2005
aesthetics. were it me, i would let the puter know i removed it, if i did.
here is a cut/paste from the last post i did with EGR stuff (too lazy to try and type it again):
I'll take a stab at this.
i see no cons, unless you have a show car and like it clean under the hood (aesthetics).
the EGR only works at part throttle, so WOT performance is not affected. it sends spent gasses into the chambers, which cools the chambers. at the same time, injector pulsewidth is dialed back and a ton of timing is dialed-in (economy increase).
the main issue i see is letting the puter know you delted the EGR. some folks see part throttle detonation if they dont tune the car (chip, TwEECer, etc) after deleting the EGR. the EGR dilutes the mixture (inert gasses), which is why less fuel and more timing can be introduced (the diluted mixture is less volatile). now if those inert gasses are removed (EGR deletion), but the puter does not know, it will continue to dial back pulsewidth and add timing. hence detonation in cruise (EGR active) conditions.
some folks delete it and dont notice detonation, some do. just something to be aware of if you do get some.
good luck.
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
L
Exhaust 95 gt pypes catted x pipe
  • Lx5.0fiend
  • Aug 22, 2025
1994 - 1995 Specific Tech Sep 18, 2025
revhead347
D
Throttle Body Spacer
  • dropteeth
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
nicholase
