  • 1994 - 1995 Specific Tech
Why did this happen to my Upper manifold gasket??? *PICS*
  • Thread starter Thread starter juiced_94gt
  • Start date Start date Aug 21, 2007
juiced_94gt
1,143
Southern California
Aug 21, 2007
  • Aug 21, 2007
well these are some pics of what the gasket looked like when i pulled the upper to install 2 injectors that werent firing... the wet spot smells like fuel, do the ports look normal?? all the vaccume lines are tight with hose clamps holding them what would cause this?? the only bolt holding the upper to lower that was loose was the rear one on the drivers side...would that have caused this to happen, these pics were taken after 300 miles of break in driving.
F
Fopar
178
San Marcos, CA
Aug 21, 2007
  • Aug 21, 2007
you sure they weren't stuck open instead of not firing? Looks like some reversion going on... which is normal to some point. If those ports are drowning in fuel I can see that happening. Either that or possibly leaking intake valves...
D
ddranger
minnesota
Aug 21, 2007
  • Aug 21, 2007
wouldn't a leaking fuel pressure regulator do that too
gcomfx.com
3,690
Republic, MO
Aug 21, 2007
  • Aug 21, 2007
Mine looked like that from the first time I put the new engine in. Mine looked more like oil though. I replaced the gaskets, but the spacer is still soaked in.
I think my engine is still building up pressure in it. I may try valve cover filter on the valve cover instead of the factory setup with the vent in the filler tube going back to the intake route.
Badazgt.
115
  • Aug 21, 2007
all upper intake gaskets are goin to be oil soaked
divit250r
314
Columbia City, IN
Aug 21, 2007
  • Aug 21, 2007
That looks a lot like mine, and my problem is the PCV valve spitting oil into the upper by way of the vac. lines. Then it gets sucked down the ports closest to the PCV and stains the phenolic spacer, gaskets, and both halves of the manifold. Do you have an oil seperator on your PCV? That's supposed to help, but I haven't tried it yet.
Scott
gcomfx.com
3,690
Republic, MO
Aug 21, 2007
  • Aug 21, 2007
Guess our PCV valves are well lubricated?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Aug 21, 2007
  • Aug 21, 2007
try putting an air/oil seperator inline from the PCV to the intake on that vac line
gcomfx.com
3,690
Republic, MO
Aug 21, 2007
  • Aug 21, 2007
Got a link to a cheap and small one?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 21, 2007
#10
  • Aug 21, 2007
  • #10
I wouldn't worry about it
Looks like a small amount of oil mist has discolored the gasket
It looks like it was sealing and that is the main thing
Grady
SQUEEZE&STROKE
SOUTHERN CA
Aug 21, 2007
#11
  • Aug 21, 2007
  • #11
Go to Home depot/lowes.
Go to compressor section.
they make a smll one for like $10. Get some pipe nipples and some vac line and you are golden.
I bought the largest one they have for my Lightning so I wouldnt have to clean that damn intercooler any more.
urban96
3,464
Syracuse, NY
Aug 22, 2007
#12
  • Aug 22, 2007
  • #12
i did the same exact thing. it looks just like the one steeda sells for $70
gcomfx.com
3,690
Republic, MO
Aug 22, 2007
#13
  • Aug 22, 2007
  • #13
See I knew I should ask. Thanks... do you leave them hanging or do you mount them to the firewall or other place?
Black95GTS
1,644
Marlborough, MA
Aug 22, 2007
#14
  • Aug 22, 2007
  • #14
It's an oil issue... I don't think its gas. Look to the PCV as others have said.
Stock TFS gaskets are known to have problems. I went with after market units when I did my install after doing some research.
Adam
gcomfx.com
3,690
Republic, MO
Aug 22, 2007
#15
  • Aug 22, 2007
  • #15
Aftermarket TFS gaskets? Do tell.
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
J
  • JRC99
  • Apr 19, 2025
JRC99
J
Engine Is there something wrong with my engine or is this just normal modded fox behavior?
  • AnthonyA1234
  • Aug 30, 2022
2K
Fox 5.0 Mustang Tech Aug 30, 2022
90sickfox
