  • 1994 - 1995 Specific Tech
Why doesn't vortech make aftercoolers?
  • Thread starter Thread starter toppdogg_1
  • Start date Start date Feb 23, 2004
T
toppdogg_1
89
  • Feb 23, 2004
I was just curious to if anyone know's why vortech doesn't make aftercoolers for 94-95 Mustangs
onebad95
Sherriff of Bling King County
Jul 22, 2002
1,237
At the end of the track waiting for you !!
Feb 23, 2004
  • Feb 23, 2004
my guess would be that there isn't enough of them to make it profitable. I have a theory that if you do the fox throttle body conversion that you can make the fox kit work. Again, this is only a theory.
YEAHLOH95
1,249
EVERETT,PA
Feb 23, 2004
  • Feb 23, 2004
i had the the same thought if you do a fox throttle body conversion you could run a fox aftercooler !i was thinking of trying it down the road .or just using a nitrous kit as a cooler ?
ProKiller
3,064
15
78
PA
Feb 23, 2004
  • Feb 23, 2004
my guess would be no room. have you looked in there? with the Vortech on the right side and the ducting, there is no room for it. if the profitablity was a case, then why whould they make them period??? why they make a kit for the 2000 Cobra R when they only made 200??
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Feb 23, 2004
  • Feb 23, 2004
Talked to Vortech about this awhile ago. There isn't enough room for one.
Bling
127
L.V N.V.
Feb 23, 2004
  • Feb 23, 2004
After a Fox TB swap it looks possible. I have tons of room over there now, but I don't know anyone local w/ an aftercooler so I can check the fit. I'm actually thinking about going to a straight discharge head unit and trying to incorporate a front mount I/C into mine. Need something for these 120+ deg summers around here
Y
yellow1995Cobra
2,959
Massachusetts
Feb 23, 2004
  • Feb 23, 2004
I read a thread over at www.superchargerhelp.com where someone got an aftercooler to work with the FOX body TB. They had to use a straight discharge blower, then a series of bends to the aftercooler. I would try a search over there in the vortech S trim section.
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
Vortech v3 Si Blow-Off Valve
  • seanmahoney
  • Jun 9, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 9, 2025
seanmahoney
9
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
