why Fuel whooas
Mustangr
217
boise Id
Just had it dyno tuned was running great and now..... Just coming into power band boost starts to increase then it starts holding back. I see fuel pressure fall off completly. If I stay in the throttle it backfires it surges badly.
what gives internal pump maybe T-rex filter Hmmm
Any drop in fuel pressure would typically indicate a problem with either the pumps or the filter. Either pumps would be adequate for your power levels by themselves…..so I would first look into replacing the fuel filter.
What is your base pressure set at? What fuel pressure regulator are you running?
I dont know. Now the brand new MSD distributor that I got with the Accel DFI kit is now faulty..I had to return it to MSD. We will see. I want to get the
Stealth kit from Aeromotive. Has anyone had problems or info about it.
