the common term freeze plugs are not what most people think they are for... if you are going to have an extreme system pressure build up it will blow a radiator hose or something else.. these plugs are used during the casting process to remove any excess sand that was use in the process. each engine is cast in a one time use hard packed sand. the plugs are then driven in place to cover the hole. high performance blocks offer threaded core plug holes for a threaded pipe fitting to be installed as well.
Correct. I have seen blocks freeze and crack before any plugs come out.
call me lucky..my freeze plug popped
. The point here is that they are not designed to pop out with freezing coolant, even though they often do, which led to the misnomer of "freeze" plugs in the first place. I too have been lucky with one block. All 3 plugs on one side popped out. None did on the other side. Unfortunately I was not so lucky with the heads. One of them did crack. I was running straight water in the summer while I was testing the engine. The car wasn't ready to drive so it sat until winter. By then I had forgotten I had put water in it. i am not saying that they do not pop out but they are not designed for that feature. added benefit yes. as for the design its cheap to install a stamped steel peice of metal instead of a threaded hole and plug.
