Wideband AFR Sensor Location
Before the cat. If you have long tubes, in the collector is a good spot. If not, you just need it before the cat but after the "collector" on shorties. You need to get all of the exhaust from all of the primaries on that side so that you get an accurate reading. After the cat and your reading will be way off. There is usually a bung already there if they are aftermarket, though.
