Hey so i did a big tuneup on my 91 stang this weekend and replaced all the normal stuff and a few other things. I took it out for a little test ride and when i put the clutch in while rolling around in 1st or 2nd gear the RPM's jump up to like 2G or 2.5G and they stay there and i have to shut the car off to get it to reset and then in a couple minutes it does it all ovfer again. Tomorro, i am going to try to check the voltage of the TPS or and swet it to around .94-.95 volts. and i will check the IAC, but i dont know what i would be looking for with the IAC. I cleaned out my TB when i tuned the car up, so i was thinking that might have something to do with it. The car also idled quite high (about 1100 rpm) so i was also going to mess with the idle screw and see if i could straighten that out. Thanx in advance for all the advice or help....later
