Wierd timing issue
  • Thread starter Thread starter S-Car-Go
  • Start date Start date Aug 6, 2005
S-Car-Go
332
San Jose, CA
Aug 6, 2005
  • Aug 6, 2005
Hi All, Last week I bought a 68 convertible. It’s got a 289 (or 302) /C4 with a 4.11 trac-lok. I’m planning on swapping in a 351/T5 this winter, but I’d like to keep this motor running in the mean time. Anyway, last night I changed the plugs, but when I checked the timing, I found it at about 20* AFTER TDC. I had to jump a tooth to get it anywhere near TDC and then it wouldn’t start (popped back through the intake). When I put it back to 20* ATDC, the car starts and idles fine, plenty of power down low, but runs out of power quickly as RPM’s go up. I’m going to be looking at it later today but so far I think
1) jumped a tooth on the timing chain
2) Harmonic balancer scale is sliding.
Any other ideas to check out would be appreciated. Oh yeah, It’s got a Petronix ignition. Could something on that cause this?
iskwezm
4,159
20
79
Rowland Heights,California
Aug 6, 2005
  • Aug 6, 2005
check the elastomer ring on the balancer like you guessed.I think jumping a tooth on the timing chain is unlikely.
StephenMarsh
25
West Los Angeles
Aug 7, 2005
  • Aug 7, 2005
This may sound stupid but - you did get the firing order correct right? 289's and 351's are different if memory serves. I have NO idea if that would even cause the problem your describing but thought I'd throw it out there.
G
grego37
576
Fresno CA
Aug 8, 2005
  • Aug 8, 2005
did you check your timing at idle "initial timing" with the vacuum advance dis-connected and hose plugged?
Sounds like your advance may not be working properly in your dist.
to check your timing to make sure its advancing .
hook the vacuum advance hose back on the dist.
With your car in park, using a timing light, have a buddy slowly bring up the RPMs while you read the timing. It should stop climbing at approx 3000rpm, when it stops climbing read your timing. This reading is your total timing.
If you can use a timing light with a 'zero' dial its much easier, all you need to do is use the TDC mark on the balancer and read the back of the 'zero' dial for your "total timing"
Dont forget when ever you change/adjust your timing, to go back and adjust the carb.
S-Car-Go
332
San Jose, CA
Aug 8, 2005
  • Aug 8, 2005
Thanks all! I think I got it. Balancer was fine and timing chain was fine. Combination of things. Pulled #1 plug and brought the motor up on compression. Pretty close to TDC. Good! Pulled the distributor moved it a couple of teeth and static timed it at 10*BTDC. Confirmed firing order and she fired right up. Bumped inital timing to 14*. Down side is that even at 14* initial, I still only have 30* total (with dial-back timing light). I'd like to see ~36 total. Grego, good call. I think I'll pull petronix out this weekend and a junkyard dura-spark is going in.
Now I have a bunch of really noisy lifters Motor has prolly been revved pretty hard due to the 4.11 gears...
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
CAMTWO1070
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
Strange issue with timing Fixed
  • 2003 mustang gt modded
  • Oct 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 4, 2025
