  • 1994 - 1995 Specific Tech
Will a Panhard Bar work with the 4-link
  • Thread starter Thread starter abusedstang
  • Start date Start date Jun 4, 2005
abusedstang
103
East Hampton, CT
Jun 4, 2005
  • Jun 4, 2005
I am gonna replace the stock LCA/UCa combo with some aftermarket units. I was gonna use the ford racing UCA's and some aluminum LCA's with an adj. spring perch. Would a panhard bar work with this combo?, or would there be binding issues? I've heard of people removing one of the UCA's so there is no bind. It sounds kinda risky. Any ideas on how to keep the axle in check without dumping over a grand on a torque arm or 5 -link kit would be appreciated.
DougNuts
2,596
Georgetown Ky
Jun 4, 2005
  • Jun 4, 2005
I think that would be a decent budget build up. FRPP uppers, MM lowers, and MM panhard rod.
It should all work fine together. When you can finally afford it, swap out the upper arms for a torque arm or evolution motorsports 3 link setup.
N
Nobody
2,515
Kenmore, WA
Jun 4, 2005
  • Jun 4, 2005
The Panhard bar works with the 4-link and DO NOT remove the uppers. You cannot remove the uppers until you get a torque arm or ladder bars. The 4-link works together to control the vertical, lateral and Wind-up (rotational) motion of the axle.
UCA's & LCA's - Vertical movement, wind-up
PHB - Lateral placement
The Panhard bar takes the task of lateral placement off the control arms -that is all it does. It does not control the wind-up. Therefore, the 4-link still controls the vertical and wind-up. A torque arm controls the wind-up. When you have a torque arm, you have specific parts to control each movement exclusively.
TA -Wind-up
PHB -Lateral placement
abusedstang
103
East Hampton, CT
Jun 4, 2005
  • Jun 4, 2005
Great. Thanks for the info. I'm gonna be working with 10k that I've saved up. I might just get the torque arm with the rest. I figure 400 bucks for one, give or take. I want to keep the suspension mods under 2k for everything. Thanks again.
bimmertech
1,123
merriam, ks
Jun 4, 2005
  • Jun 4, 2005
i have a panhard bar and only run 1 uca all the time and have found the rear has better control with only one. the uca does control pinion movement and side to side movement. removing one allows the panhard bar to control side to side while still maintaning pinion movement. for proof just take a look the 05 stang, kinda just a cheap knockoff of f-bodies, but works none the less.
abusedstang
103
East Hampton, CT
Jun 4, 2005
  • Jun 4, 2005
doen't that put serious stress on the one UCA? On the 05', it's parallel to the LCA's and the 04' s and older have them at damn near a 45 degree angle. Wouldnt that bend the UCA at the axle?
baglock1
The Bartender
6,612
Space Coast, FL
Jun 4, 2005
  • Jun 4, 2005
People have run a single UCA when running LCA's and a PHB. It's called a poor man's 3-link (PM3L). It's definately not a great plan and does indeed put undue stress on the UCA, but more importantly, it places a huge amount of stress on the torque boxes. It also creates a LOT of rear steer which can be completely counter productive in making a Mustang handle.
As mentioned, the best way to go about it is to use a TA/PHB setup or do one better and convert to a 3-link.
As a matter of fact, here's an EvM setup on ebay right now...
Evolution Motorsports Watts Link
Evolution Motorsports Trilink
Prices are damn good too.
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
D
1994 GT issues
  • DLB1985
  • Jul 2, 2022
1994 - 1995 Specific Tech Jul 2, 2022
General karthief
