  • SN95 4.6L Mustang Tech
Will ABS Light give an ODBII Code?
  • Thread starter Thread starter sbelyo
  • Start date Start date Sep 6, 2006
sbelyo
192
  • Sep 6, 2006
And will the predator be able to tell me the code?
ultrashock2112
100
Vancouver, Canada
Sep 6, 2006
  • Sep 6, 2006
You need a special scan tool to electronically diagnose ABS problems, you can't read it with an OBDII Code reader.
R
Red2000GT
2,450
Regina,Sask.Canada
Sep 6, 2006
  • Sep 6, 2006
The Predator will read and display all codes from a OBDII FORD vehicle.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Sep 6, 2006
  • Sep 6, 2006
no it will not.. the preditor will only read the PCM it will not read your other modules
to get ABS, ICM and GEM codes you need a true scan tool.
sbelyo
192
  • Sep 7, 2006
That's what I thought. Would a place like autozone be able to read those codes? They don't charge, where as the ford dealer wanted 100.00 for diag. Right now the ABS light is off. It came on yesterday for a short ride to home depot. Then when I left work it was off and didn't come on for the 90 min. ride home. It came on again when I stopped at walmart. I noticed the brake fluid was below the max line, so I filled it up. So far on the way to work it did not come on.
I'm guessing that it will not show any codes if the light is off right?
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Sep 7, 2006
  • Sep 7, 2006
if it comes back on, pay attention to how fast you're going
sbelyo
192
  • Sep 7, 2006
The first time was 30 - 40 mph and the second was when I turned the key and started the car.
sbelyo
192
  • Sep 7, 2006
what is the cheapest scan tool that can read abs codes from ford?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 8, 2006
  • Sep 8, 2006
check with MATCO, MAC, or Snap-On. you are looking for a minimum of $1500-$7000 for a decent scan tool. a good scan tool is gonna cost you closer to $10,000.
P
Pennywise2
Banned
May 16, 2006
1,379
#10
  • Sep 8, 2006
  • #10
Mike is right you need to get the code read from a scan tool.
Superhereaux
chicks make me feel inadequate
538
South Texas
Sep 8, 2006
#11
  • Sep 8, 2006
  • #11
generic OBDII codes are for emissions purposes only
you'll need a ford scan tool to read all DTC's, in other words take it to a ford dealer
low fluid will throw an ABS code though and cause the light to come on. fluid needs to be at the correct level for ABS to function properly
Mike97gt
it doe snot
10,633
Sep 8, 2006
#12
  • Sep 8, 2006
  • #12
your better off just taking it to the dealer... the 100.00 includes one hours worth of diag so your not just getting a uneducated guess.. diag gets a lot more involved at times then just reading codes, and those autozone guys can cost you money when they start guessing.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 9, 2006
#13
  • Sep 9, 2006
  • #13
could've just been your low fluid, do a couple of hard brakes on the highway and see if the light trips
sbelyo
192
#14
  • Sep 12, 2006
  • #14
I think it was just the fluid... The light only came on and went off in 2 seconds after filling up to the max line. It has not come on at all in the last 4 days. I'm going have the fluid replaced soon, but if it comes on again I'll take it to the dealer.
DTNODYA
831
#15
  • Sep 12, 2006
  • #15
It's either low fluid, one of the sensors, or air in the system. At least that's what I assumed with my truck. I bled the system, checked the fluid, and ultimately ended up replacing a $10.00 sensor. Morale of the story (since it's not a Mustang) is that you should troubleshoot the previously mentioned things if you have time ... before you go pay $100. HOWEVER, if you don't know how to bleed brakes well, you should not try to do this step because if air gets into the ABS system you will have a helluva problem that will require the 'special tool' Ford has.
When your ABS light is on you still have brakes. My Mustang does not have ABS and I personally am glad ......
A
GT ABS Module in a 2001 Cobra
  • Aamer309
  • Oct 17, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 3, 2026
Mustang5L5
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
2001 GT stuck in 2nd
  • 01gtslider
  • Jul 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
01gtslider
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
