will i need new pushrods with gt40ps??
Stock GT40P heads use pedestal mount rockers, and therefore do not need hardened pushrods. If you upgrade the heads to use stud mount rockers, then you would need the hardened pushrods.
In either case, you ought to consider measuring for correct length to make sure your valvetrain geometry is ideal.
Dave
96darkhorse said:
ohh yeah him going with an fti custom cam matched to the heads...heads are not milled
Still measure them. FTI custom grinds use the standard base circle, so stock length (6.272) should work fine, but it's always nice to be sure. Kinda like how you are going to degree the cam, because that's the Right Thing To Do(tm). :D
Dave
96darkhorse said:
thanks hairy canary!!! if would need diffrent ones....what size do you guys think i would need??? guesses
Very likely right in the neighborhood of the stock ones. I ended up with 6.300 myself. It can vary based on the head, valves, and rockers. You can get a good pushrod length checker from Summit for about $20.
Dave
