  • SN95 4.6L Mustang Tech
Will Something Break???
  • Thread starter Thread starter blacknblue2002
  • Start date Start date Dec 12, 2006
blacknblue2002
159
Va Beach, Va
Dec 12, 2006
  • Dec 12, 2006
well I was thinking about getting some sticky tires for the track....but I'm beginning to worry that with more traction something's bound to go....my last dyno was @ 335 rwhp, but that was when I was running 6psi...since then I've bumped that upto ~9-10psi with the addition of a boost pipe and grippier/smaller pulley...the car definately pulls a lot harder now but I have no traction
Any opinions on the subject???...I really want to get better times at the track, but don't want to fork out the money on new rubber if it's going to cause me to lose my clutch or rearend (or both)
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Dec 12, 2006
  • Dec 12, 2006
I say get some drag radials and just don't do 5k clutch drops off the line and you should be fine. The stock rear-end on these things is pretty beefy, Its the axles that'll go first.
blacknblue2002
159
Va Beach, Va
Dec 12, 2006
  • Dec 12, 2006
sounds like a plan...thanks for the input
the98stang
2,408
Clovis, CA
Dec 12, 2006
  • Dec 12, 2006
The stock clutch and axles/diff are bound to go with 360+ WHP. However, you can reduce the chance of them breaking by taking precaution as mentioned above. Don't dump the clutch, and keep your revs around 4,000 or lower. Before you hit the track MAKE SURE you have enough back up money for a new rear end or clutch. It's just insurance. Also have a AAA card ready or tow truck available.
Some people make 300+ runs on the stock rear end on DR's. Some blow it on the first run. Your just rollin' the dice. But I want to give my rear end HELL before they break . My moto is "don't dick with it if it isn't broken!"
Just go easy on the launches, and it should hold for a while.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Dec 13, 2006
  • Dec 13, 2006
Anytime you add power and traction you increase the lchance of a failure.
You need to figure out how fast you want to go, how much breakage are you willing to accept and if you want to spend the extra cash to sure up the driveline..
the way i look at it is it's a big time waste of money to supercharge your car just to make it run slower or near what it ran N/A due to bad traction... BUT when you hook the stock clutch and the stock 28 spline axles and the unwelded axle tubes and tourqe boxes take a beating.
So are you willing to spend the money to fix what breaks, and are you willing to spend the money to upgrade as needed.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Dec 13, 2006
  • Dec 13, 2006
Not trying to say it won't break.. but.. I've got a friend with an '03 Cobra vert running 15x10's with slicks in the rear and skinnies up front on a stock GT rearend with 4.10's.. He's putting down about 460rwhp and he dumps it off the line every time. He's been like that for 2 years on stock axles/differential... And another buddy who used a stock 8.8 in his drag cars for 5 years without any breakage. He only upgraded to a 35-spline due to the 438ci windsor and powerglide, since he would be making ~800rwhp and launching at 5500rpm.
Just a bit to think about.. But still, you never know how well your rearend will hold up at the track
Just don't use DR's and trackbite at the same time
01KBGT
14
Long Island
Dec 13, 2006
  • Dec 13, 2006
I just went with a similar set up, 373 at the wheels, stock clutch, stock rear, and 315 Nitto Drag radials, launched around 3000. Don't dump the clutch and you should be fine.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 14, 2006
  • Dec 14, 2006
I had a friend doing 6 grand clutch dumps with 475HP and 3.73's with everything else in the driveline stock. He didn't break it but I think he only ran 5-6 times before he sold the car.
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
  • Locked
SOLD 2000 Ford Mustang Gt Nasa Cmc Racer Or Hpde
  • SPEED DETAILS
  • May 17, 2016
5K
SN95 Mustangs For Sale (1994-04) May 17, 2016
SPEED DETAILS
