Will switching intake benefit me?
  • Thread starter Thread starter TheBocSez
  • Start date Start date Apr 9, 2006
TheBocSez
652
Converse, TX
Apr 9, 2006
  • Apr 9, 2006
Just installed a rebuilt engine, unfortunately I reused the old lifters and discovered that some are in need of replacement. Since I will be taking the upper and lower off to switch out lifters, I was thinking of changing intakes while Im at it.
I currently have a Stock upper, opened up for a 65mm TB with a TMoss ported lower intake. I was thinking of changing to a 93 Cobra intake. Would it be worth the money? By worth the money, I mean will the power improvement be enough to justify the 300+ cost? The car is a street car and My current combo is:
1991 LX Vert
302
Custom Cam ( 218 @.050 / .520 lift / 114 lsa)
E7 Powerheads
Crane 1.6 rr
BBK 1 5/8 shortys
UPR o/r X pipe
AOD
2800 Non lock Stall
4.10's
Lentech VB
Future upgrades may include a Powerdyne but not sure how far down the road that will be.
So what do you think? Will the improvment be noticable enough to justify the cost?
Thanks
bentley429
Banned
Nov 25, 2004
528
Connecticut
Apr 9, 2006
  • Apr 9, 2006
I would say yes. I put a edelbrock performer and 70 mm tb on after the powerdyne and it made one hell of a difference. So when you do the supercharger you'll be all set.
Repostyle
538
Portland, OR
Apr 9, 2006
  • Apr 9, 2006
I've got the cobra upper and lower and I noticed a difference right away, plus I'm set (aside from heads) for when I finally get the cash for a SC.
TheBocSez
652
Converse, TX
Apr 9, 2006
  • Apr 9, 2006
Now, Im playing devils advocate here, but did either of you run a TMoss ported lower before upgrading or did you go from totally stock to what you have now?
The reason I ask is that the TMoss lower flows pretty good. I noticed a difference from stock to the ported lower so Im not sure what the differece between the ported lower to the Cobra would be. I am sure the I would notice a difference from factory stock to Cobra but how much so from ported stock to Cobra?
Thanks
J
jjd975
4,236
louisville,kentucky
Apr 9, 2006
  • Apr 9, 2006
The stock intake has trouble feeding stock heads so I would image it would still struggle (even when ported) to feed ported stock heads. I would do a swap.
Plus down the road you wont want the stocker with the blower. If you can find a cheap Performer intake I would go that route.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Apr 10, 2006
  • Apr 10, 2006
Really? The stock E7 heads flow about 160cfm tops - here is what one of my ported stock lowers ported for E7 heads was flow tested at:
Subj: Flow Test
Date: 2/16/2004 5:57:49 PM Eastern Standard Time
From: "greg@xsrcylinderheads.com" <greg@xsrcylinderheads.com>
To: MOSSTPSA@sbcglobal .net
Sent from the Internet (Details)
Hey, I recieved the intake today, and flowed it. Here are the #'s,
I have yet to flow a stocker. Soon as I get one I will flow it too.
Also, I flowed the intake without a clay entry, which would have
netted a 10-15 cfm boost.
Runner #'s...........flowed @ 28"s
1-186 5-183
2-201 6-200
3-198 7-191
4-200 8-198
(195cfm avg)
Later, Greg(XSR)
And the stock upper flows ~190-195cfm by itself too, so I think the ported stock combo has E7, ported E7 or Gt40 heads covered pretty well...........
TheBocSez
652
Converse, TX
Apr 10, 2006
  • Apr 10, 2006
Here are the reported intake side flow numbers for E7 Powerheads from
http://www.allfordmustangs.com//Detailed/630.shtml
.100 64.2
.200 123.4
.300 175.8
.400 204.3
.500 217.2
Now with the above listed flow number from TMoss and my cam specs, it seems pretty well matched. The heads are out flowing the intake at .500 lift, but the intake valve is only open at .500 for a short portion of its cycle. Its in the .200 - .400 lift range for longer periods of time. So, if the heads are flowing 204 cfm at .400 valve lift and TMoss's intake is flowing 195 cfm avg. is 10cfm at .400 valve lift worth $300.00??
I know someone is bound to post that I seem to be looking for reasons to stay with the TMoss lower but I am countering arguments in order to feel fully convinced that its worth the expense.
If any of my reasoning or understanding of valve events and flow are significantly wrong please feel free to correct me, always willing to learn something new.
J
jjd975
4,236
louisville,kentucky
Apr 10, 2006
  • Apr 10, 2006
The intake should flow roughly 10% more than the heads. You need more intake.
If your only worried about lift in the .2-.4 range you really never needed a custom cam, stocker would do fine.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Apr 10, 2006
  • Apr 10, 2006
YOu would gain some peak numbers, but you will loose some low-mid range power. There is an example of this very situation on my site - the Rio5.0 graphs where he changed from a ported intake to a Cobra (Community-Photo Gallery-Stock Lower Intake Results). Average power over the rpm band was the same for both, but the Cobra made more peak. If it's peak your worried about - change the intake, but don't expect big HP/$ spent gains.
In the end, it's what you want to do.......I'm not rying to convince you one way or the other - just giving you information to base your decision on.
  • dan50
  • Jul 18, 2026
dan50
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
