  • SN95 4.6L Mustang Tech
Will these springs work?
  • Thread starter Thread starter Seraphitia102
  • Start date Start date Apr 29, 2005
Seraphitia102
will post boobie pics for a supercharger
Oct 11, 2004
737
California
Apr 29, 2005
  • Apr 29, 2005
The link below shows some springs that I'm interested in because of the slight drop. I don't want my bumper to hit the ground so i don't want to lower my car too much so I figured these springs would be ideal for me. Do you know if these springs will fit on my 2001 Mustang GT Convertible? I believe convertibles may support different springs...
http://store.cal-mustang.com/cm_able/showdetl.cfm?&DID=7&Product_ID=9466&CATID=20&CM_SA=1
M
MustangJunkie
97
Northern VA
Apr 29, 2005
  • Apr 29, 2005
My suggestion would be to lower your ride by the standard 1.5"--not too much and not too little. You have to be careful and make sure that you get a spring kit made especially for convertibles. I got the Eibach Pro-Kit and I couldn't be happier with it. It can be had for $233 delivered from coximport.com (model 3530.140). And the ride is superb with those springs!
Seraphitia102
Oct 11, 2004
737
California
Apr 30, 2005
  • Apr 30, 2005
this is the way my convertible looks like now, do u think the 1.5" drop is still front bumper safe on dips and speed bumps?
K
kstang69
153
atlanta, georgia
Apr 30, 2005
  • Apr 30, 2005
it would look great and for speed bumps, just go slow over them maybe at an angle a bit...you have to slow down for speed bumps anyway, slowing down a little more isnt a big deal
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Apr 30, 2005
  • Apr 30, 2005
cal mustangs customer serivce is very poor and they will never get my business ever again.You shouldn't be safe with droping your car 1.5"
all around some people go 2" and never have a problem.If you are only
looking for a 1.5" drop than the Eibach Pro kit is the right springs for you.
I do recommend you get new shocks and struts though like Koni,Bilstien,
etc. Also if you go 1.5" you will not have to do caster chamber plates but,
if you go any lower than they will be needed.After two or three week after
your springs settle you need to get an alignment.Alignment is very important!
M
MustangJunkie
97
Northern VA
Apr 30, 2005
  • Apr 30, 2005
Your car looked like mine before the drop. Believe me, 1.5" is PERFECT! (Actually, to be technically accurate, the drop for the convertible kit is 1.3" for the front and 1.4" for the rear.) I didn't like the look of my Mustang for a long time because of its stance but I didn't know how low I should drop it because I didn't want mine too low. When JonJon posted his before-and-after pics of his dropped Mustang about two months ago, I had to ask what he used because it was the drop I was looking for. It's awesome.
Driving around, I have had no problems with the drop at all. As for new shocks and struts, I don't know if that's absolutely necessary. I guess it would depend on how many miles you put on your car so far. If it's under 20k miles don't worry about it. If it's over, then they're something worth considering.
Seraphitia102
Oct 11, 2004
737
California
Apr 30, 2005
  • Apr 30, 2005
thanks for the help guys i didn't know about an alignment either.
i have 42,000 miles approx. so perhaps i should get new struts and shocks.
i'm thinking i will go for the eibach convertible springs, thanks guys!
Ghostface
226
Apr 30, 2005
  • Apr 30, 2005
Eibach pro-kits should be fine on your car. Since the drop isn't too severe you won't need heavy duty shocks like Bilsteins or Konis which are expensive. You can get Mach 1 shocks for around $180 for all 4, I think thats about how much I paid for mine.
GDawg
1,469
Nevada
Apr 30, 2005
  • Apr 30, 2005
I don't know what kit you are talking about but who would want their rear dropped more than their front?
I have H&R Supersports. The drop is ~1-3/4" in the front and ~1-1/2" in the rear. If you don't want to go that low just get the H&R Sports. Best springs out there. <Period>
C
chrisbudl1
436
springfield MO
Apr 30, 2005
#10
  • Apr 30, 2005
  • #10
I have a link with h&r SS springs installed. My air dam scrapes pulling out of some parking lots, andI might be nervous if it was going to be my bumper or side skirts scrapeing. I want a saleen 2000 kit, but like I said I would be nervous. The additional suspension parts can add up fast to, to make everything run right. I needed everything in my signature(susp. related)
H
HMSPORT
Banned
Mar 30, 2005
60
#11
  • Apr 30, 2005
  • #11
Go with the Eibach pro kit or Saleen springs (made by Eibach) You will be ok with 1.5" drop. I would suggest spending some money on quality struts and shocks. The factory pcs. are basically junk after 40k plus miles. I would also add some caster/camber plates.
twogts4us
4,188
12
79
Dunedin, FL
Apr 30, 2005
#12
  • Apr 30, 2005
  • #12
The springs in the link are the Ford B & C springs, which will work perfectly on the SN95.
Seraphitia102
Oct 11, 2004
737
California
May 1, 2005
#13
  • May 1, 2005
  • #13
what are caster/camber plates?
assuming I were to lower my car tomorrow, would all I need to bring to a professional installer is the springs, c/c plates, and 4 new shocks?
C
chrisbudl1
436
springfield MO
May 1, 2005
#14
  • May 1, 2005
  • #14
basically yes, and not to sound rude, but you should probably read up on the boards, if you are unsure what c.c. plates are. We were all there at one time. They allow extra adjustment with alignment. springs, struts, c.c. plates,balljoints,bumpsteer. could change when you drop it.
Ghostface
226
May 1, 2005
#15
  • May 1, 2005
  • #15
most likely you won't even need CC plates with the Pro-kits.
M
MustangJunkie
97
Northern VA
May 1, 2005
#16
  • May 1, 2005
  • #16
Yep. I didn't need them. If you're going to drop more than 1.5" then CC plates definitely need to be considered.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
9
RECEIVED OFFER TO BY MY 92 LX CONVERTIBLE
  • 92StangGirl
  • Mar 23, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 23, 2026
General karthief
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
