will this fan work??
jmd2914
937
Napa, California
i was at autozone and asked for a fan out of a 93 mark viii and part no. for the piece that they gave me was 733690 theres no pic but does this sound like the right one? its a 14" s blade fan, i thought mark viii fans were 18". help!!
This is the best picture I have of my fan prior to installation. It might give you a better idea of the size
jmd2914 said:
you put a mark viii fan in your car right?
Yeah, I made the swap between the stocker and the Mark Viii fan. It takes some triming of the M. Viii fan shroud to make it thin enough to fit between a 3 core radiator and my water pump pulley. But it's in there now and does a great job at cooling my car.
No not as much as I did. You can read my progress thread and my radiator swap thread. Both will have pictures of before and after to give you an idea.
Let me go find them.
Don't worry about the timing either. A circular saw with a sharp blade can be used (carefully) to trim the shroud down...
Edit: I found my progress thread with pictures of the fan installed. I can not seem to find any pictures of the radiator swap though. Let me check my website for those.
http://forums.stangnet.com/showthread.php?t=627646
