will this flexplate work?
bjl95mustang
1,495
Austin,TX
I'm getting a flexplate to get balanced with my rotating assy and i would like to kow if this one will work or not. Will i have any problems becuase it's.138 thinck insted of .075?
Thanks,
Brandon
Hawks Racing 50oz Imbalance SFI Flywheel for SB Ford. This unit is brand new in the box and is in PERFECT OPERATING CONDITION !!!! This unit fits SB Fords with 164 tooth gear and 50oz imbalance. (Bidder is responsible for researching fitment) This is the flex plate you need to comply with NHRA/NMRA etc. rules!!
.138" Thick Cold Roll Carbon Steel Plate (stock is .075)
Double Welded on Both Sides of the 164 tooth ring gear
Externally Balance to 50oz OEM Specs
Long Lasting Rust Proof Zinc finish
14.23" outside diameter
11.5" converter hole pattern
SFI Compliant 29.1
NHRA Legal
