Window adjustment...
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Just wondering how to tighten/adjust the windows. It's a 90 LX with power windows. When I roll the drivers window up, right when it gets to the top, the window tilts forward and doesn't seal at the back where it rolls up into. Just wondering how to tighten this? Pics, details, websites? Thanks.
THis happens to me every now and then too because I replaced my drivers window at my house and didnt have a rivet gun so I just used bolts to hold the glass in place. It came loose after a year and I had to reposition and tighten the bolts. Best bet would be to remove your door panel and check and see how the glass is held in / see whats loose or binding as the window goes up. Door panel is easy enough, just philips head screws and two 12mm bolts. Unless of course the hardware on my door panels is wrong which wouldnt surprise me. Either way, basic set of hand tolls will do it. A cheapo door trim remover will help you remove the push pins without damaging anything.
Nick, how are your guide bushings for the window? Seems to me that if it tilts, that indicates that a bushing (the bottom one is likely) might have excessive slop. With the door panel off, you can give it a once over and see the dynamic at hand. Just be careful - the motor has finger crushing ability if you have your hand near the regulator pieces.
Good luck,
My step father (ASE Master Tech, whoopty right? lol) had my car while I was on vacation for this problem. The window not rolling up all the way... He said all the bushings where good, but the motor gear was almost gone.. said he was surprised it was still working. So he replaced that. He also said he "tightened up" the window. I already had the door panel off, and it looks as if the window is held in place by white bushings and a big rivet in it. That would make it non adjustable right? Can't be "tightened"? While the door panel was off, I pushed the window up, and it pushed right into place. But once I roll it down, and back up, it tilts forward again. Also, I noticed if I hold the window at the rear and push down with my fingers on both sides of the glass, it will go up correctly. Like I said, it seems like it's "loose" so it tilts forward.... It also flops around a little when it's half down, but less after my step father worked on it. Any more help? :D
Nick, since I have a vert, our set-ups are different (I think hardtops have window frames - let me know if they dont).
I am no ASE master Tech, so I hate to go against what your step-dad said, but the motor gear should have had nothing to do with the window going up straight (one of the white soft gears, right?). It is nice to have fresh gears in there (they are sacrificial so if a kid sticks his hand into the window as it goes up, it wont hurt the kid too bad - the plastic gear strips instead).
Anyhow, The motor bolting in in academic - no adjustment. But though he said that the bushings were tight, you say you can apply resistance or help the window and it goes into place - that tells me there is slop in there.
My bushings were kinda bad but I didnt replace them like you should. I used a U shaped (instead of D-shaped) bushing so I could install it without removing anything (otherwise, I think the glass has to come out entirely - I think). I would have to look, but there was adjustment on mine. Maybe it was that the entire window track (that vertical rail in the middle) had bolts at the top and bottom, and I could adjust that. I think that is how the stang window was. It's been a couple years.
Here is something to try: have you lubed the center rack (that the bushings slide over) and most importantly, the channel and the front (and back, if applicable) for the edges of the window glass? I routinely lube these channels (I prefer silicone spray, but any light grease would work too - it is messy no matter what you use). I saturate the felt in the channels and the resistance in the window goes down dramatically. And you know what - in some cases with this lessened resistance, the window will track right and position correctly at the top.
I still think that if you give it a once over Nick, you will see what is going on, and maybe a couple of these little things can make it work.
Good luck with it. :nice:
Thanks so much, JT. Windows and stuff like this I've never really got into. I know all the slides and track is greased very well. You are right, I would think it is a bushing (with 104,000 miles on it). I took it apart, looked at it for a few minutes... got frustrated and put it back together lol. I might attempt it Sunday, because last time it was getting dark and I wanted to wash it also, so I just put it back together. The wind noise is kiiiiiillllllling ME! I hate it!!! I wanna punch the window lol. I might attempt it again, or bring it back up to Mark (step dad), and ask him to look at it again. This way I can watch him do it and know what to do next time. This is how I learned everything in the first place... WATCHING HIM!! :)
If it is in the bushing, the only adjustment would be to drill out the rivet head and re rivet or use a bolt. Rivet would obviously last longer before slop developed but Im pretty sure you need a large rivet with a big rivet gun. The kind that look like bolt cutters. I may be wrong on that, I know thats what newer cars are using but like Hissin said, I havent looked at the window setup in a real long time, its not fresh in my head.
