T TheFox New Member Mar 16, 2009 57 0 0 May 24, 2009 #1 May 24, 2009 #1 how does the quarter window moulding be removed or can it??mine is loose on the body but not on the window itself what would you say??
68stang351 Founding Member May 16, 2002 850 9 39 Savoy TX May 24, 2009 #2 May 24, 2009 #2 TheFox said: how does the quarter window moulding be removed or can it??mine is loose on the body but not on the window itself what would you say?? Click to expand... It cannot be removed they are made that way!
Beasty306GT Active Member Dec 19, 2002 671 4 28 Oxford,Mass May 24, 2009 #3 May 24, 2009 #3 they dont come off there part of the window
T TheFox New Member Mar 16, 2009 57 0 0 May 24, 2009 #4 May 24, 2009 #4 they are loose on the body are they made that way also im trying to repair some scratches and need to paint any suggestions
ID89GT 10 Year Member May 26, 2008 1,659 18 49 Spokane Valley, WA May 24, 2009 #5 May 24, 2009 #5 Id check on the back side of the window to see if some of the nuts came off that hold the window on, or maybe they are loose.
TRWXXA Member Jan 18, 2003 190 1 19 RIGHT BEHIND YOU!!!... Made you look. May 26, 2009 #6 May 26, 2009 #6 The sealant behind the moulding can shrink with age. Remove the windows and reseal them, or just try to snug up the bolts a little (not too much though).
