  • 1994 - 1995 Specific Tech
Window problems - Help
  • Thread starter Thread starter Igofaster13
  • Start date Start date Apr 2, 2009
Igofaster13
170
San Diego
Apr 2, 2009
  • Apr 2, 2009
My girls 95 gt driver power window is acting up. The window was jumping up&down while going up/down, now its up but does the jumping thing and goes nowhere usually. Looking for what part could be bad, so I can go ahead and order/replace for her.
Thanks!
nunly94gt
1,595
Mobile, Al
Apr 2, 2009
  • Apr 2, 2009
Motor and regulator, we replace them all the time here at the shop.
HISSIN50
34
129
Apr 2, 2009
  • Apr 2, 2009
The plastic rollers that ride in the reg tracks can be problematic.
And the nylon bushings in the motor are a wear item, especially if a window has not been moving smoothly (the bushings act like a torque-clutch).
You'll have to remove the door panel and do some looking.
Good luck.
Igofaster13
170
San Diego
Apr 2, 2009
  • Apr 2, 2009
Cool, will tear into it and see whats up, thanks for the info!
pirotec354
127
Grand Rapids, Michigan
Apr 3, 2009
  • Apr 3, 2009
I had this same problem. If you can hear the regulator running but the window doesnt move, thats a pretty good indication that the bushings inside of the regulator are bad. Mine were, so instead of spending good money on a new regulator I spent four dollars on the bushings and now the window works good as new. Sometimes those regulators are a pain in the but to get apart. And putting the new bushings in isnt that fun either. Good luck
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Rear window failure
  • Moondog2178
  • Jul 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 22, 2025
Moondog2178
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
K
Severe Drivetrain Shaking
  • KeithM412
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 29, 2025
AeroCoupe
