  • 2005 - 2009 Specific Tech
window problems
  • Thread starter Thread starter lubbock05gt
  • Start date Start date Feb 22, 2008
L
lubbock05gt
lubbock, tx
Feb 22, 2008
  • Feb 22, 2008
Hving a issue with the drop down windows, they seem to drop when the door is opened but dont go back up when the door is closed, has anyone else had this issue, before I start replacing everything. Thank you for any help I can get
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Feb 22, 2008
  • Feb 22, 2008
close the doors. with the key on, hold the switch down, and keep holding for 2 seconds after it stops. then pull up, and keep holding for 2 seconds after it stops.
should do the trick
L
lubbock05gt
lubbock, tx
Feb 22, 2008
  • Feb 22, 2008
have already tried that thanks,
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Feb 22, 2008
  • Feb 22, 2008
Sometimes you have to follow that procedure 2 or 3 times for it to work. That really should fix it. Unless you happen to have the global windows feature. Then that would be the problem.
Redfire 05
236
Lubbock, TX
Feb 22, 2008
  • Feb 22, 2008
I actually had that problem for a few days (sometime last year). Then it just went away. I assumed it to be some weird electrical gremlin? But it hasn't ever come back.
By the way I'm in Lubbock to. Howdy!
L
lubbock05gt
lubbock, tx
Feb 23, 2008
  • Feb 23, 2008
thanks for the help, I guess ill just replace the motor and see what happens
L
lubbock05gt
lubbock, tx
Feb 23, 2008
  • Feb 23, 2008
what is the global window option I bought this thing used and haven't figured out what all it has
Stangshark
50
Indiana
Feb 24, 2008
  • Feb 24, 2008
If the window is rolling up and down just fine, but not stopping where it should then it isnt the motor. Its the current setting on the computer where it thinks it should stop. I wouldnt waste your money on a electric motor that is doing its job by rolling a window up and down, it knows no different.
DarkFireGT
692
10
89
East Moline, IL
Feb 24, 2008
  • Feb 24, 2008
If you have a 2005, you may have a feature called "global windows" and it allows you to roll down the windows with the key fob. Most people who had this feature had troubles with their windows, so Ford stopped that option. If you have global windows, this could be the cause.
To find out if you have global windows, try holding down the unlock button for a few seconds. That should drop the windows. Holding down the lock button should roll them up. If that works, then you have global windows and need to go see a dealer about getting it deactivated.
L
lubbock05gt
lubbock, tx
Feb 24, 2008
#10
  • Feb 24, 2008
  • #10
thanks for all your help, I changed the motor and now it works fine.
dhthomas40
81
#11
  • Nov 18, 2008
  • #11
How much does a motor run?
dhthomas40
81
#12
  • Nov 18, 2008
  • #12
I went out to my car at lunch and tried bigcat's tip. It worked!
My problem began when I cleaned the corrosion from the negative battery thermal (some warning lights had appeared as a result of the poor connection). After the cleaning, the warnings lights disappeared, but my driver’s window was stuck in the lower position (about ¼ inch down to clear rubber door channels). Now it works fine. Thanks bigcat!
F
flyboy86
94
Vance AFB, Enid OK
Nov 18, 2008
#13
  • Nov 18, 2008
  • #13
I wonder if I have this "global windows" thing. I have an 05, and bought it used, so I dont exactly know what it has. I'm gonna go test it now!
J
justpball
#14
  • Nov 19, 2008
  • #14
the motors are only like 62.00 from the dealer but thats not going to fix his problem.
iskwezm
4,159
20
79
Rowland Heights,California
Dec 4, 2008
#15
  • Dec 4, 2008
  • #15
my stock battery(2.5 years old) died a couple of days ago and since then the drivers window, when it gets to the top will go back down.It wont stay at the top. I tried the procedure mentioned above and dint work
The battery cannot take a load now either.
07 Boss
41
Las Vegas, NV
Dec 5, 2008
#16
  • Dec 5, 2008
  • #16
Two comments:
The Ford TSB for the window drop down says to unhook the battery for 5 seconds before resetting the computer with the 2 second deal up and down.
If the window does not pop up when the door is shut, check the door close switch. My car was doing that occasionally and I would have to close the door a little harder to get the window to go up. Since then I have fixed the problem.
07 Boss
41
Las Vegas, NV
Dec 5, 2008
#17
  • Dec 5, 2008
  • #17
Two comments:
TavisB
1,048
Pittsburgh, PA
Jul 25, 2009
#18
  • Jul 25, 2009
  • #18
should do the trick
That just fixed my windows after a dead batt. Thanks!
Lostcause
81
Homestead Fla.
Nov 22, 2009
#19
  • Nov 22, 2009
  • #19
Bigcats tip worked for me as well. Windows were inop after dead battery. Thanks
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
1989 gt both doors wont lock or unlock help.
  • 1989 mustang gt
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 22, 2025
manicmechanic007
Hinge Roller repair kit
  • Rdub6
  • Aug 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 5, 2026
gkomo
R
Door Ajar issue
  • ryjack70ss
  • Jul 25, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jul 25, 2025
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
