  • SN95 4.6L Mustang Tech
Window switch VS tach accuracy..
  • Thread starter Thread starter triggz
  • Start date Start date Sep 25, 2005
triggz
1,218
Gadsden, AL
Sep 25, 2005
  • Sep 25, 2005
I know that the stock tach is known to be off by even a few hundred RPMs, but I'm worried my window switch is reading inaccurately as well.
I'm running a PEP tach adapter with a Mallory #646 digital window switch. I have a shift light hooked up to it to turn on from 3k to 5.7k (testing for nitrous). The adapters green light is on indicating it is wired properly.
Now the problem is, the light comes on at around 2600rpm, I haven't had a chance to go WOT and test the top end, but I'm sure its off as well. The light also flickers when the car bogs down to the 400rpm range.. so if it werent for the WOT switch it would spray at idle
Has anyone else had problems with the window switch reading off? Can wire length or gauge effect the signal? I extended the tach signal wire from the adapter by about 6' to reach the switch.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Sep 25, 2005
  • Sep 25, 2005
do the odometer trick where you hold in the reset button then start the car. hold the button for 15 seconds and you'll see different stuff appear on your odometer. one of them is a digital tach. it's about as accurate as you can get. check that against the other tachs to see if one is off.
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
How to get a tach signal for N2O RPM window switch.
  • drofdeath
  • Oct 6, 2023
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2023
drofdeath
