Window tint bubbles
  • Thread starter Thread starter larbec7
  • Start date Start date Nov 23, 2010
L
larbec7
25
  • Nov 23, 2010
I had window tint installed 3 years ago in my 2006 GT. The tint on the back glass and yes it has defrosters with all the fine lines going horizontal.
My question is, how can I remove the tint without tearing the metal wires?
Thanks in advance
T
The Fang
602
Tallahassee Fl
Nov 25, 2010
  • Nov 25, 2010
Heat gun then some type adhesive remover lotsa elbow grease and luck.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Nov 25, 2010
  • Nov 25, 2010
You probably should have asked your installer that 3 years ago. The shop that does mine has been doing my cars for about 15 years. They have a lifetime warranty on their stuff, and the last car that bubbled on the back took about 8 years to start. Having said that, they have a kit that can make connections in the wire elements that have been broken. When you defog your windows, you look and see which ones are not working and they can test them and remake the connections.
Follow the above though and that should be none or minimum. If one or two break, the defogger will still work really well anyway.
Good Luck.
RC
L
larbec7
25
  • Nov 25, 2010
spray
What type of adhesive remover do I want to use? Do I use a razor blade too or stay away from them.
It would be nice if they made a spray that will release it all off
1wildGT
1,026
Abilene TX
Nov 29, 2010
  • Nov 29, 2010
This:
YouTube - Easy Way to Remove Automotive Window Tint
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
