  • SN95 4.6L Mustang Tech
window won't go down!!??
  • Thread starter Thread starter matsm21
  • Start date Start date Jul 17, 2005
M
matsm21
241
Long Island
Jul 17, 2005
  • Jul 17, 2005
for two days the passenger side window went down only around midnight when I was comin home from work, but not during the day. now it doesn't work at all. I took apart the door, but couldn't access the motor. I'd have to take the sheetmetal apart. I checked all the plugs and they were solid. the thing is, its not even trying to go down. thers no grinding, humming, anything. all other 3 windows work. any ideas?
thanks
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 17, 2005
  • Jul 17, 2005
probally the motor. take the door panel over and reach behind the sheetmetal you should feel the motor there. make sure the connector is connected. then hit the area of the motor on the sheetmetal side with a hammer. don't go nuts just tap it. and see if the window works then.. if it does then it's the motor..
you can check with a test light too. find the conenctor and remove it. on the harness side push the switch in the down pos. and see if you have power in either of the plugs.. then push the switch up and see if you have power in the other wire in that connector. you an check ground this way too by connecting your test light too the pos. battery terminal.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Jul 17, 2005
  • Jul 17, 2005
slam the door shut and try again.
M
matsm21
241
Long Island
Jul 17, 2005
  • Jul 17, 2005
I'll have to get a test light and try that. does the wires that lead to the motor go directly to the drivers side door switch? maybe its a connection there?
Mike97gt
it doe snot
10,633
Jul 17, 2005
  • Jul 17, 2005
could be. most common faults are the motor and the master switch (drivers door)
M
matsm21
241
Long Island
Jul 17, 2005
  • Jul 17, 2005
I checked the drivers side, and everything seemed to be in order. I do have a leak right by the little speaker though. I would think it would affect all of the buttons though. what # fuse are the windows? I don't have my shop manual here.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
J
Windows won’t go up when car is running
  • Jraesims
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 15, 2025
J
Car won’t start
  • JLB
  • Nov 15, 2025
SN95 4.6L Mustang Tech Nov 15, 2025
nickyb
  • brandyn200
  • Jun 20, 2026
AeroCoupe
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
