I im2damncool Founding Member Dec 28, 1999 249 0 0 Chico, CA May 20, 2006 #1 May 20, 2006 #1 My passenger side window stopped rolling up. It's electric in a 94 GT. Doesn't even try or make noise. Any help?
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 May 20, 2006 #2 May 20, 2006 #2 I would check fuses. Then the connector at the motor for power. If you have power, bench test the motor and see if it works. Good luck.
M mackey Active Member Jan 25, 2003 1,284 1 38 Beverly, Massachusetts May 20, 2006 #3 May 20, 2006 #3 Slam the door while holding the button up. Mine gets stuck sometimes.
The Green GT No 13 year olds are safe around me. 10 Year Member Jan 8, 2006 1,269 19 99 Louisiana May 20, 2006 #4 May 20, 2006 #4 I had to take my door panel off two nights ago and once I tapped the motor with a hammer it came right up. Also check the switches. Mine went bad a while back and hitting them made it work.
