Curious where I can find info on the intake differences between the Ford small blocks. Some were dry, some were wet, I'm trying to see what combination would work best for me.
B302 block and regular 20deg heads.
The Boss 302 block is still a Windsor 302. Since you're using standard Windsor heads, you'll need a standard 289/302 intake. All of them use a thermostat in the intake so all of them are wet. Some have a rear coolant crossover, many do not.
