walksinshadow
Finally finish up the Monroe Handler rear end fiberglass work. Once that is done, Align the doors correctly and follow that up with the final fitting of the Monroe Handler front end. Meanwhile finish up the exhaust system ive been working on. Then make sure everything is good to go with the engine before i do switch in the new MSD distributor and MSD 6A and eventually get started on redoing the wiring
Guess I better get back to work.
I finally got my stang back on all fours after the wilwood disc brake conversion and five-lug axle swap.
