Wire hiding question
  • Thread starter Thread starter Jack's95gt
  • Start date Start date Dec 16, 2007
J
Jack's95gt
443
Huntingdon Valley, PA
Dec 16, 2007
  • Dec 16, 2007
I'm doing a wire hinding project on my 93 lx. I have a mini starter and a 3g alternator upgrades. I'm thinking of pulling off the right side header and running the 4 gauge cable from the alternator to the starter stud. Is there any reason this wouldn't work???
I mounted the coil on the engine since I have 95 mustang front engine dress and running the wires up from the back.
I'm running the yellow and green/red wire for the alternator up from the back. I'l mounting the BAP and starter solenoid in the left fender well. I'm running the main hardness and brake lines under the back pinch joint.
I'm trying to come up with a way of maybe putting the vacuum tree in the cowl area. Maybe by installing a tee from the upper intake and brake booster and then in the cowl area. Any suggestions welcomed.
I removed the windshield washer tank and pump and will need to install one in the cowl area if a small one could be found. It's a requirement for my state inspection.
J
Jack's95gt
443
Dec 17, 2007
  • Dec 17, 2007
Bump
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
