depends on what you plan to do with the fuse box. leave it in the same spot, cut a square hole so all you see is the fuse box cover, or stuff it all in the fender. i left it in the same spot and i'm glad i did. i already had to look in fusebox for a fuse.
with my setup, i removed the whole harness and fuse box, cut a hole small enough to fit everything through and still not be visible. mounted the fuse box in the exact same spot. routed the harness in the fender between the rad and rad support to the other fender. only had to extend the passenger corner and head light. everything else fit fine including A/C.
