wire O2 sensors
  • Thread starter Thread starter humaxxx
  • Start date Start date Jun 20, 2007
H
humaxxx
35
  • Jun 20, 2007
hello,
We have a problem with our mustang 5.0. If we dump the codes from the computer we get 41 and 91. We have bolt on new o2 sensors but we still get the codes 41 and 91. We have also measure the resistance between the ground from the computer and the sensor. And the resistance between the + from the sensors and the pins/wire at the computer (29/43). This was all OK.
But at the sensors there is a third wire......wat is the use of this third wire...must there be a 12v signal at this wire????????:
Can somebody help us
thx
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 20, 2007
  • Jun 20, 2007
humaxxx said:
hello,
thx
The third wire is usually the 12 volts for the O2 sensor heaters.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer, actuator & sensor wiring
Fuse panel layout
Vacuum routing
HISSIN50
34
129
Jun 20, 2007
  • Jun 20, 2007
Those codes do not indicate O2's being the issue - they indicate a lean condition. This can be due to a vacuum leak, bad MAF or any number of other factors.
Just something to consider as you troubleshoot.
Good luck.
H
humaxxx
35
  • Jun 20, 2007
I have measure the voltage on the third wire and there is no 12v signal on the wire.......Can that be the problem???? Or as the engine is warm the heater inside the o2 sensor is no more nessarly???
thx
H
humaxxx
35
  • Jun 21, 2007
nobody!!!!
The car is running very rich ...its stinks badly!!!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 21, 2007
  • Jun 21, 2007
Go back to the diagram I posted. and look at the lower LH vcorner. You will find the O2 sensor circuit. If there is no 12 volts on the gray/yellow wire, then the fuseable link, or wiring is faulty.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • dan50
  • Jul 18, 2026
dan50
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
A
Electrical New O2 sensor harness has no jumpers (91/93)…
  • afjLX
  • Dec 11, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
afjLX
A
