Wiring 97 Cobra/msd Removal Help Please
ppartain
73
Long story short I have decided the MSD DIS-7 ignition box is causing me issues. Now that being said I don't have the bypass plug so I've decided to just pull it off. After pulling the old instruction sheet off MSD website (have to select obsolete instructions) and comparing my chiton manual I pulled all the tape and plastic off the wires. Looks like the 2 negative wires and the one positive wire needs to be spliced back to the wire clip that attaches to the coil itself. This will be the same process either side. Basically the MSD wires are spliced into the 3 wires coming out at the valve cover and spliced into the 3 wires at the coil connection 6 butt connections at each coil. Is the little wire that's grounded on the coil is that your radio interference capacitor? I'm going to cut all these wires and attach them per factory and I want to be sure. Thanks guys/gals
http://s1347.photobucket.com/user/P...2-22161-000016F613A93FD8_zps6ce54d6e.jpg.html
