wiring diagram
  • Thread starter Thread starter rudy herrera
  • Start date Start date Oct 13, 2009
R
rudy herrera
110
Oct 13, 2009
  • Oct 13, 2009
hye i need to see a wiring diagram to instal a car stereo in a 1990 lx guy i bought my car of janked his stereo out i tryed instaling it but the sterio would keep getting its setting erased like the radio stations and stuff
i also cant find the fuse for the sterio any one know were it is located thanks for your help
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 13, 2009
  • Oct 13, 2009
Sounds like you don't have the constant power wire hooked up correctly. Just buy one of the pigtails for it at like wal mart or something and it is pretty self explanatory then.
R
rudy herrera
110
Oct 13, 2009
  • Oct 13, 2009
will thatt cable be the orange one
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 13, 2009
  • Oct 13, 2009
No, constant power is usually yellow, ignition switched power is usually red, then black should be ground, then all the other wires are the wires going to the speakers. Orange will be illumination, and the blue is usually the antenna wire.
R
rudy herrera
110
Oct 13, 2009
  • Oct 13, 2009
thanks how about the fuse were will that be at
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 13, 2009
  • Oct 13, 2009
Fuses should be on the left under the dash on the drivers side. If its and 87-89 they will be under the removable cover just left of the trim piece directly under the steering wheel. If it is 90-93 it will be under dash on the far left with a black cover on it showing what each fuse represents.
R
rudy herrera
110
Oct 13, 2009
  • Oct 13, 2009
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 13, 2009
  • Oct 13, 2009
No problems, thats why we are here
Z
Electrical Radio wiring diagram for 91 fox
  • Zeke1995
  • Jan 11, 2026
Fox 5.0 Mustang Tech Jan 12, 2026
Zeke1995
Z
  • Mindseye007
  • Aug 16, 2026
Mindseye007
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
02 Sensor Wiring Problem
  • mpence
  • May 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 14, 2025
mpence
M
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
