wiring guru's please help
fedup
41
i did a 5.0 conversion used the 4cyl headlight harness for a few days everything was good put in a v8 harness and now i have no parking lights and the blinkers work way to fast. i also changed to a 140 mph speedo and now my oil pressure is off the gauge its so high before it read fine please help before i do something bad to the car (Purposely)
JBeezy53 said:
Hey your name fits you.:lol:
Sorry I'm no help with that wiring.
that is the plan i hgave built this car from the bare shell up was red on red 4cyl auto now black on black 5.0 5 speed it has been almost 4 years im just about fed up
I hope you get it figured out. Sounds like the car is going to be NICE!! When you build it from scratch everything is the way you like it.
Hopefully "jrichker" stumbles across here soon, he always has numerous solutions for this kind of stuff.
The parking light wire color on a GT is brown. It can be found under the dash if tracing wires. I would start at the headlight switch and ensure you have the parking-light output-signal from the switch.
Do all the bulbs work when your TS's are on and are they the correct wattage? Flashing fast can indicate too much juice passing through the flasher relay.
Does your OP gauge move, or is it kinda stuck at full tilt any time the key is on? If the latter, I would make sure the sending unit wire is not pinched or shorted to ground (which pegs the gauge full bore). A DMM can make quick work of it.
Good luck.
Good luck.
if i unplug the op wire the gauge reads nothing it read good oil pressure before i changed the guage cluster and the parking lights do not come on at all in the front and the blinkers work really fast all the bulbs are right they worked before i changed the harness
The wiring scheme & some of the wire colors changed in 91. Since you didn't post your car year/mods in your sig, it will be much more difficult to troubleshoolt any problems you have.
No, it is not there for us to snoop and see any "Secrets" you have hidden away under the hood. Be a good stangnetter and update you sig for future reference & don't keep us guessing.
Mixing body harnesses between model years before 91 and after 91 can cause problems. Don't use a 91 body harness on a 89 car and expect not to have problems. It may work OK or it may not. The only way to know if it works OK is either to test it, or have both wiring diagrams side by side & compare them.
sorry i am very computer illiterate it is a 93 with f3 harness's so everything should be fine but it's not the car is built bone stock as a 93 5.0 5 speed
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
now just an idea if im not using the headlight foglight switch and just still using the headlight only switch from the 4 cyl would that make a difference? cause im thinking that might be the problem i have the right switch when i find it in my garage caus it's a mess (10 car stable) with 2nd floor (all fords and parts)
The diagram was posted for the wiring layout and colors. It helps a lot to see what it is supposed to look like when you start chasing things with an Ohmmeter. The switch would be the same between the 4 cylinder & V8 cars.
now the oil pressure problem i beleive this is it did the change the sending units in 90 or 91? if so would that be my problem as the motor was out of an 89
