wiring problem
  • Thread starter Thread starter bottomlesspit 2
  • Start date Start date May 22, 2006
bottomlesspit 2
17
del rio, tx
May 22, 2006
  • May 22, 2006
ok. ive been fooling around with the wiring in my mustang trying to figure out why the power sometimes shut off and have found out what the problem is. when i press my steering wheel to the right, the power shuts off, but when i press it over to the left, everything works fine, but it only happens when the engine is running. when the engine is off, nothing's wrong. what could explain this scenerio and how could i fix it. any hints or possible solutions are welcomed.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 22, 2006
  • May 22, 2006
The ignition switch & associated wiring are suspect.
There is a FREE recall on Ford ignition switches. They overheat and sometimes catch fire.
Copy down you VIN number and call the Ford dealer nearest you. Tell them you want to see if the ignition switch recall for Fords & Mustangs was done on your car. They will ask for the VIN number & check it against the master database. If it isn't in the datbase, then you can schedule an appointment to have the switch replaced for free. The TSB is #95S28, and don't let them tell you that they don't do that anymore...
9
90lxfoxbody
264
  • May 22, 2006
i agree with jrichker. the ignition switch is activated thousands of times over the life of the car, and over time they can develop an area of "free play' where they will not activate any or all of your electrical items, accessories etc. next time this happens, try turning the ignition switch forward or backward a bit to see if it fixes the problem.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
  • Mindseye007
  • Aug 16, 2026
Mindseye007
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
