wiring question
  • Thread starter Thread starter mustangcobra93
  • Start date Start date May 25, 2005
mustangcobra93
928
  • May 25, 2005
Tonight I tucked the interceptor away in the kick panel and made a little headway in starting on the harness install so I can take advantage of the boost tables. Pic one shows my new GM harness which fits my map sensor perfectly. Pic 2 shows the harness on the interceptor I need to connect the three wires coming off the map sensor harness to. The wires on the harness are labeled A, B, and C. I know A is the ground, B is the sensor signal, and C is the +5v sensor power. However, I don't know which one to plug to which connector on the interceptor harness. On the interceptor harness the wires are: pink w/ brown stripe, pink w/ purple stripe, and pink w/ yellow stripe. Does anyone have any idea which should go to which? The last pic shows how I tucked away the interceptor.
ss93cobra
1,422
Wilmington NC
May 25, 2005
  • May 25, 2005
Glad to see the GM harness suggestion worked.
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
May 25, 2005
  • May 25, 2005
Here are a couple pics of the plug on my Interceptor II..
Without flash...
With flash...
mustangcobra93
928
  • May 25, 2005
you are the man! thank you very much, that is exactly what i needed!
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
May 25, 2005
  • May 25, 2005
Glad to be of service..
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
  • dan50
  • Jul 18, 2026
dan50
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Resolved Ignition switch questionable
  • Dontknowchit
  • Mar 14, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
General karthief
