06 v6 mustang
is any wobble acceptable? should it be immovable?
I ask because i am chasing a really annoying wheel vibration when over 50mph
I had a balance at costco last week
i had an alignment last week
i replaced the front strut assemblies
inner and out tie rods replaced
front control arms replaced with GT500 control arms
sway bar bushings replaced with urethane
sway bar links replaced
just replaced the driver side hub bearing assembly.
even replaced rear control arms and shocks...just for good measure.
tire still shakes. a little. when off the ground. if a little back and forth is normal then fine. but still shakes like a mofo going over 45mph
could rim be slightly bent? i am not seeing it.
bad balancing?
only has very slight play back and forth.. not up and down. thats solid
did i just replace the front hub bearings for nothing? Have 193K on it so figured probably not at its peak freshness anyway. The passenger side bearing was definitely in need of replacing though.
I'm running out of things to replace. lol
bad balancing?
