wont fire up
  • Thread starter Thread starter jay1718
  • Start date Start date Aug 25, 2004
J
jay1718
18
  • Aug 25, 2004
i have a 1971 mach one 302 dropped in my fox body. i rewired the entire car for drag. the problem is that the motor will not fire , any suggestions
orangecapri
189
Alden, KS
Aug 25, 2004
  • Aug 25, 2004
Are you getting spark? Are you getting fuel?
88stangmangt
2,332
Stafford,VA
Aug 25, 2004
  • Aug 25, 2004
3 things spark,fuel,compression is all you need for a motor to start hunt it all down..........
J
jay1718
18
  • Aug 25, 2004
i have a holley 750 carb and i am getting fuel and i do have compression, how could i check for a spark
The Shape
2,224
East ARKANSAS Delta
Aug 25, 2004
  • Aug 25, 2004
Pull a spark plug wire off. Put a screwdriver into the end of it and hold it close to the block. Have some one hit the key and see if a spark shoots from the screwdriver to the block.
extozy
93
Longview, TX
Aug 25, 2004
  • Aug 25, 2004
you could just pull the plug and the wire and put the plug in the wire and touch the block with the plug.. shouldn't that work?
The Shape
2,224
East ARKANSAS Delta
Aug 25, 2004
  • Aug 25, 2004
I am sure it would. Problem is do you feel safer holding on to the insulated handle of a screwdriver or the sparkplug wire?
J
jay1718
18
  • Aug 26, 2004
i am getting spark anything else it sounds like it wants to start but it doesn't
8YO_VTEC
63
Burke, Va
Aug 26, 2004
  • Aug 26, 2004
180 out maybe?
dastang2
2,020
tx
Aug 26, 2004
#10
  • Aug 26, 2004
  • #10
probably 180 out but you need to go down at least 100 cfm's on that carb, not the NO RUN problem though.
J
jay1718
18
#11
  • Aug 28, 2004
  • #11
i adjusted the timing and it seems to get closer but it is backfiring through the carb, should i keep adjusting the timing,
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 28, 2004
#12
  • Aug 28, 2004
  • #12
Take the coil wire out of the distributor. Pull #1 plug, put your finger in the spark plug hole. Have someone crank the engine until it starts to blow air past your finger. Stop cranking, turn the engine by hand (breaker bar on the harmonic balancer bolt, or put the car in gear and push) until the TDC mark on the harmonic balancer lines up with the pointer on the passenger side of the engine. Loose the distributor hold down bolt, remove the clamp, cap and wires, disconnect the wiring harness. Pull the distributor straight up.
The following re-install depends on the engine being lined up as in the previous instructions.
To re-install, turn the distributor rotor to point to #1 cylinder position on the cap. The#1 position is about 11 o'clock if 6 o' clock is the front of the engine. Line the rotor up with it pointing at the #1 spark plug position on the cap and drop it in: you may have to twist the shaft some to get it to engage the oil pump shaft. 10* is stock for most 5.0s' 12*-14* is good for more pep if you are not into NO2 or power adders.
Remember that Non HO engines use a different firing order from HO & 351W engines.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
