wont fire.. yes I searched
notchback
1,950
St Clair Shores MI
ok i finished my head and intake swap wednesday night but a dead batt kept me from playing.
i charged it and cannot get it to fire.
here is what i know.......
* yes i removed and installed the dizzy correctly
* i have spark on the correct cylinder, my daughter cranked it while i shot the timing light and it hits about 0-4
* i have 40 psi at the rail
i removed the spout to kill the advance and still nothing
point in the right way... i need to fire it up !!!!!!
won't fire
If you had the wires off the distributor cap did you get the rotation/wiring of the distributor right?
Give it a shot of starter fluid. If it starts for a moment and sounds normal you can then concentrate on a fuel problem. Or if it dont start/backfires you know you have a timing issue.
Did you hook up all the ground wires between engine and firewall ?
