- Mar 7, 2023
- 1
- 0
- 1
Car was running great
88 fox mass air 347 Cam not sure. aluminum rad 2 ele fans. msd coil n 6al n dizzy. heads not sure deffently after market. 24lbs injectors. upper n lower intake both after market not sure witch 1. intake spacer. 65mmTBbbk with spacer. it has a harmonic for super charged 347. i look it up.
i got a novi 2000 renagade kit. i was going to put on. but got it second hand. so i had to up grade so things. so i got bbk fule rail. 42lb injectors i think 250 fule pump. and a bunch of structural stuff.
I removed egr n pipes to heads I put fuel rail in an injectors in an pump. Then realized I was missing some stuff. to to make the super charge bracket. Got sick left it alone for a year. Now just trying to get it running again. Gas was leaking out of 1# injector long story short my computer burned some caps. So I got a mega squirt2 pnp. That fixed the 1# injector from sticking wide open. But now it wont start. Has fule pressure. Deffently has compression. Spark check no spark with dizzy in. spark when I took it out an spun it by hand. I put a ground wire on hold down bolt.now I have spark. When I crank it. It turns no back fire nothing. But some times when I pump the peddle it trys 1 time it was kinda running but terrible. Had the peddel on the floor an it was barely running. Like a little faster than cranking rpm. As soon as I lifted my foot dead.
My wide band reads 22 when I first try to start it then after a while of cranking. It goes down in the 10’s my o2 is also reading fule in exhaust. Is that normal? Even though it wont start? Im at a loss??????
