Engine Won't Run Right Since I Tried Maf
91gte303
144
18
28
Lake city,SC
Well.kinda like that. My friend talked me into ignoring y'all and trying the 93 cobra maf......just y'all said not to do.well it ran weird,so I took it off and put the stock one back on. Then it got worse. Wouldn't idle right( have an E303 cam...but after the problem started,car sounds bout stock at idle). While driving normal,it would spit,shudder, back fire and vibrate crazy hard. If I floored it,it would clear up For a mile and then start front and back firing. Front fired so hard one time,I thought it blew the air filter off. Got the car home and unplugged the maf while it was running,and no change.so I replaced the map ssensor. Now it does make a difference when I unplug it. Pulled the plugs while I Was at it and it was run
Was running REALLY lean. Now it drives almost normal.just still down on power and still sounds like it has a smoothish cam,even when i turn the idle down to 600rpms. What cam it be? Ran it for codes and it pull 4 of them. 3 where unrecognized and 1 was about the maf voltage being below minimum. That was with koeo. Then I did it with koer and it pulled no codes. HELP
You need to post both the engine off and engine running codes to get a full picture of your problem.
Post the numerical values for all the codes and I will give you the 5.0 Mustang definitions and fixes.
First off, do as Jrichker suggested, pull codes and post them and he will help you along.
Second, did you personally install the E303 cam or have it installed? If not and it came from a previous owner then chances are he lied or was misled himself from a previous previous owner.
Also, can you list the mods that you are sure you have for us including any smog equipment that may be missing or deleted.
FIrst- disconnect the battery for 1/2 an hour with your headlight switch on. Then reconnect the battery- see if that clears up any stored memory from the Cobra MAF. Is the stock MAF wire intact, and clean, Is the screen intact. Do you have 19 or 24lb injectors and what EEC?
Then run the codes and report back
Reactions: jrichker
with the Key On Engine Off, it says that the MAF voltage is below minimum, and the NDS sensor(no idea what that is) is malfunctioning. Also says that the vacuum regulator is malfunctioning. The charcoal canister is gone. that air pump has been deleated,the EGR valve is nonfunctional, but is plugged into the wiring to keep the computer happy. the MAF wire is intact and is clean. but, the screen has been removed. The cam is an e303. I know this because i was with my uncle when he tore the engine down after buying the car.
I cleared the codes with the scanner and the car started running fine for a while. but now its back to popping thru the exhaust under light load. I replaced the spark plugs,JIC with autolight platinum's.
Also,there was one day,that i spun the engine 7Krpms. but that was honestly an accident and has never happened again.
the EEC is the stock 5.0
as the car sits,
stock 1991 short block
1993 cobra heads(stock springs. Gettin the TFS's soon)
1.6 roller rockers
e303 cam
19lb injectors
exploder intake
65mm TB
stock MAF(have the c&l just wanna figure this out before i change anything)
the TPS sensor is set at .88 volts
full length headers, O/R H pipe, 40's dumped. 2-1/2"
180* thermostat.
electric fan.
codes are 67,85,84,29,33,96,11
is there a way to find out if the computer is bad?
i keep getting told that its either the computer of the pick-up on the distributor. but im told that if it was the distributor, it would just be bad or good. not GOING bad. so could it just be that the '93 cobra MAF screwed the computer up?
A MAF swap is not likely to damage the computer.
Fix all the codes and you will get an 11 if the computer & everything else is good.
Code 29 - Vehicle Speed Sensor (VSS) is an electronic sender mounted on the speedo pickup gear on the trans. It works the cruse control for both 5 speed and auto trans cars. The VSS is used to tell the computer to speed up the idle as you slow to a stop. This helps keep the engine from stalling when you slow down for a stop sign or stop light.
Check to see if the electrical connector is plugged into it. Clean the connector & contacts with non flammable brake parts cleaner prior to replacing the sensor, as that may fix the problem. The sensor cost is under $30 and it is easy to replace.
Code 33 - Insufficient EGR flow detected.
Look for vacuum leaks, cracked vacuum lines, failed EGR vacuum regulator. Check to see if you have 10” of vacuum at the EGR vacuum connection coming from the intake manifold. Look for electrical signal at the vacuum regulator solenoid valves located on the rear of the passenger side wheel well. Using a test light across the electrical connector, it should flicker as the electrical signal changes. Remember that the computer does not source any power, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
Check for resistance between the brown/lt green wire on the EGR sensor and pin 27 on the computer: you should have less than 1.5 ohm.
Backside view of the computer wiring connector:
a9x-series-computer-connector-wire-side-view-gif.71316
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
EGR test procedure courtesy of cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve or see the EGR test jig drawing below. Connnect the test jig or to directly to manifold vacuum.
Do not connect the EGR test jig to the EVR (Electronic Vacuum Regulator).
apply 5in vacuum to the valve. Using the test jig, use your finger to vary the vacuum
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect EGR test jig to the hose coming off of the EGR Valve.
Use your finger to cap the open port on the vacuum tee.
snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
did the vacuum gauge show about 2-5 in vacuum?
if not the EVR has failed
EGR test jig
egr-test-jig-gif.58022
The operation of the EGR vacuum regulator can be checked by using a test light applied across the wiring connector. Jumper the computer into self test mode and turn the key on but do not start the engine. You will hear all the actuators (including the EVR vacuum regulator) cycle. Watch for the light to flicker: that means the computer has signaled the EGR vacuum regulator successfully.
Code 67 –
Revised 2 Nov 2012 to add definition of the NSS functions for both 5 speed and auto transmissions
Cause of problem:
clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. This code may prevent you from running the Key On Engine On tests.
External evidence from other sources claims that a code 67 can cause an idle surge condition. Do try to find and fix any issues with the switch and wiring if you get a code 67.
What the NSS (Neutral Safety Switch) does:
5 speed transmission: It has no connection with the starter, and the engine can be cranked without it being connected.
Auto transmission: It is the safety interlock that prevents the starter from cranking the engine with the transmission in gear.
What it does for both 5 speed and auto transmission cars:
The computer wants to make sure the A/C is off due to the added load on the engine for the engine running computer diagnostic tests. It also checks to see that the transmission is in Neutral (5 speed and auto transmission) and the clutch depressed (T5, T56, Tremec 3550 & TKO)). This prevents the diagnostics from being run when the car is driven. Key On Engine Running test mode takes the throttle control away from the driver for several tests. This could prove hazardous if the computer was jumpered into test mode and then driven.
The following is for 5 speed cars only.
The NSS code 67 can be bypassed for testing. You will need to temporarily ground computer pin 30 to the chassis. Computer pin 30 uses a Lt blue/yellow wire. Remove the passenger side kick panel and then remove the plastic cover from the computer wiring connector. Use a safety pin to probe the connector from the rear. Jumper the safety pin to the ground near the computer.
Be sure to remove the jumper BEFORE attempting to drive the car!!!
Code 84 EGR Vacuum Regulator failure – Broken vacuum lines, no +12 volts, regulator coil open circuit, missing EGR vacuum regulator. The EVR regulates vacuum to the EGR valve to maintain the correct amount of vacuum. The solenoid coil should measure 20-70 Ohms resistance. The regulator has a vacuum feed on the bottom which draws from the intake manifold. The other vacuum line is regulated vacuum going to the EGR valve. One side of the EVR electrical circuit is +12 volts anytime the ignition switch is in the run position. The other side of the electrical circuit is the ground path and is controlled by the computer. The computer switches the ground on and off to control the regulator solenoid.
Code 85 - CANP solenoid - The Carbon Canister solenoid is inoperative or missing. Check vacuum lines for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always energized any time the ignition switch is in the run position.
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel. The canister is normally mounted on the passenger side frame rail near the smog pump pulley.
attachment.php
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
The purge valve solenoid connector is a dangling wire that is near the ECT sensor and oil filler on the passenger side rocker cover. The actual solenoid valve is down next to the carbon canister. There is about 12"-16" of wire that runs parallel to the canister vent hose that comes off the bottom side of the upper intake manifold. That hose connects one port of the solenoid valve; the other port connects to the carbon canister.
The purge valve solenoid should be available at your local auto parts store.
Purge valve solenoid:
The carbon canister is normally mounted on the passenger side frame rail near the smog pump pulley.
Carbon Canister:
getimage.php
Code 96 causes & tests 91-93 models. – KOEO- Fuel pump monitor circuit shows no power - Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits. The fuel pump circuit lost power at one time or another.
Revised 07-apr-2013 to add check for corrosion and damage in fuel pump relay socket
Clear the codes by disconnecting the battery and turning on the headlights for about 5 minutes before reconnecting the battery. This will clear any remaining codes. Drive the car for several days and dump the codes again. In many cases, this clears the 96 code.
Look for a failing fuel pump relay, bad connections or broken wiring. The fuel pump relay is located under the Mass Air Meter on Fox bodied stangs built after 91. On earlier model cars is under the passenger seat. On Mass Air Conversions, the signal lead that tells the computer that the fuel pump has power may not have been wired correctly. See Mustang Mass Air Conversion | StangNet
Diagram of the fuel pump wiring for 91-93 cars.
attachment.php
Look for power at the fuel pump - the fuel pump has a connector at the rear of the car with a pink/black wire and a black wire that goes to the fuel pump. The pink/black wire should be hot when the test connector is jumpered to the test position. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. No voltage when jumpered, check the fuel pump relay and fuse links.
attachment.php
Power feed: Look for 12 volts at the pink/black wire (power source for fuel pump relay). No voltage or low voltage, bad fuse link, bad wiring, or connections. Remember that on 92 or later models the fuel pump relay is located under the Mass Air meter. Watch out for the WOT A/C control relay on these cars, as it is located in the same place and can easily be mistaken for the fuel pump relay.
Relay: Turn on the key and jumper the ECC test connector as previously described. Look for 12 volts at the dark green\yellow wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed, or there is a broken wire in the relay control circuit. Be sure to closely check the condition of the relay, wiring & socket for corrosion and damage.
attachment.php
91-93 Models:
Using the diagram, check the dark green/yellow wire from the fuel pump relay: you should see 12 volts or so. If not the relay has failed or is intermittent. Check the inertia switch: on a hatch it is on the drivers side by the taillight. Look for a black rubber plug that pops out: if you don't find it, then loosen up the plastic trim. Check for voltage on both sides of the switch. If there is voltage on both sides, then check the Pink/black wire on the fuel pump relay: it is the power feed to the fuel pump. Good voltage there, then the fuel pump is the likely culprit since it is getting power. No voltage there, check the Pink/black wire, it is the power feed to the fuel pump relay & has a fuse link in it. Good voltage there & at the dark green/yellow wire, swap the relay.
All testing is done with the ignition switch in the Run position. Do not forget this crucial step.
The pink/black wire s should have the same voltage as the battery positive terminal +/- 0.25 volt. If not, then the fuse link for the fuel pump has opened up.
With the test jumper in place the green/yellow wire should be the same voltage as the pink/black wire +/- 0.25 volt.
If not, look at the red wire: should have the same voltage as the battery positive terminal +/- 0.25 volt.
If not, then check the yellow wire on the EEC relay located on top of the computer. This one is hard to get to. It should have the same voltage as the battery positive terminal +/- 0.25 volt. If not, then the fuse link for the computer has opened up.
If the red wire does not have the same voltage as the battery positive terminal +/- 0.25 volt and the yellow wire on the EEC relay does, then check the red/green wire on the EEC relay. It should have the same voltage as the battery positive terminal +/- 0.25 volt. If not, then the ignition switch is defective or the fuse link in the ignition wiring harness has opened up, or the EEC relay is defective.
Fix ALL of the codes! That will eliminate anything that the computer knows is a problem.
Clear all codes & retest again!
Disconnect the battery negative terminal and turn on the lights. Wait 5 minutes and turn off the lights & reconnect the battery. You will need to drive at a steady speed ~55 MPH for a minimum of 15 minutes for the computer to relearn the adaptive settings and stabilize. Do 2-3 more days of regular driving and dump the codes again.
will try this asap. BTW, I checked the numbers on the MAF sensor that started this whole problem.
F4SF-12B579-AA
AFH70-02A
3F30
From what Im reading, Its off a 94/95 Non-Superchaged V6 Thunderbird.
Still sure it didnt F**K up my computer?
A vacuum leak will cause the idle issues and some throttle issues as well depending on severity, start there, old hoses crack etc, looking at jrichker's checklist its your common thread ;)
F4SF-12B579-AA
AFH70-02A
3F30
Mismatched MAF's aren't going to screw up the computer, it will cause the car to run poorly and spit out codes.. Yes that is not the correct MAF for the Mustang EEC. Either put the stock 58MM MAF back in or use one of the MAF;s below, as they have the closest transfer curve to the fox computer. You don't want to slap on the wrong MAF as it can cause the engine to run lean even though you may not notice it. Do not swap out the electronics from one MAF to another, use the entire MAF. They are designed and calibrated as a unit.
Here is a list of interchangeable MAF's with the stock fox mustang
1995-94 Mustang 3.8L F2VF-12B579- A1a or A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2
For the flange adapter, you can either buy this adapter , look on ebay,or fab one up.
Ford MAF Adapters - Air Filters - Kurtz Kustomz Motorsports, Inc. KKM
the egr valve is there, it just doesnt work. everything that makes it work, is gone. except for the valve itself and its connector. everything else is blocked off. there is no carbon canister anymore. the vss code has gone away and the fuel pump code has gone away.
also,the switch on the clutch peddle is there,its just unhooked and i cant find "its other half"(where to plug it in at.
checked as many vacuum lines as i could get my hands on and they seem to be good. checked the base timing and its set on 14* with the lego unhooked.checked the o2 wires and they are good,checked the salt and pepper shakers and everything is ok, as far as i can tell.
its still doing it and im sick of this damn thing.
well,shims didn't fix it. I have changed damn near everything and its still fubared. looks like im switching to a carb. damn this efi stuff.
to go down a list
I have changed the computer, distributor, map sensor, maf, plugs,throttle body, and checked every dang thing.
im done.
to go down a list
im done.
What are you going to do when a carb doesn't solve your problem? If you do the swap and still have problems, you won't know if it was something wrong with the carb swap or a mechanical issue left over from your original problem.
From your original description, the backfire is a sign of a lean mixture. Are you still getting a backfire through the intake? What sort of problems are you seeing now?
What codes are you currently getting since you replaced a lot of stuff?
Carb swap is typically the knee jerk reaction when getting frustrated but it's not all that inexpensive nor easy to swap over to correctly. Stay on the current path and continue to eliminate one area at a time starting with free fixes and then on to inexpensive fixes till you find your problem.
If you have a lean condition you should spray some stuff around your intake manifold to ensure you don't have a bad gasket somewhere.
Reactions: jrichker
