WOT Sticking
  • Thread starter Thread starter SilikonBlu
  • Start date Start date Apr 20, 2004
SilikonBlu
23
  • Apr 20, 2004
I've got an '86 GT and when I hammer on the accelerator in 1st gear the throttle sticks wide open. In order to clear it, I have to kick the pedal (sometimes repeatedly). I've checked to see if it was binding on the floor mat and couldn't find anything. A quick check of the throttle cable doesn't indicate any kinks. The problem doesn't seem to occur in any other gear than first - could this be worn motor mounts? Any ideas are greatly appreciated!
NKau
1,346
Jefferson, WI
Apr 20, 2004
  • Apr 20, 2004
Probably something with the throttle body; could be that the shaft that operates the butterfly in the TB is dirty enough that it is sticking? Open and close the TB by hand and see if you can figure anything out that way. I would be VERY careful until you find the problem; drive something else until you fix the car if you can help it.
SilikonBlu
23
  • Apr 20, 2004
When I move the throttle linkage (under the TB) it moves freely. I did notice, however that the cable seems to lag - the linkage returns to it's original position and the cable then goes 'shunk' (you can hear the gas pedal hit the firewall as well). I'm thinking bad/damaged cable as I don't recall a previous 5liter doing the same thing??? (I did do a quick check of the cable - perhaps I missed something?). Also, when I 'rugged' the accelerator in the car (not running) I heard the same delayed 'shunk' after lifting my foot...
The good news is my alternate transportation is a 2003 F-150 XTR 4x4
NKau
1,346
Jefferson, WI
Apr 20, 2004
  • Apr 20, 2004
Is the cable getting hung up coming through the fire-wall? Just tossing out ideas here.........
88mustangGT
298
  • Apr 20, 2004
i had a simialer problem, i just rerouted my cable and it was all better, i guess it wasnt happy laying the way it was maybe a bend was to tight for it.
HISSIN50
34
129
Apr 20, 2004
  • Apr 20, 2004
as said, sometimes the butterfly will wedge and stick when opened all the way. cleaning often helps. sometimes slight filing is needed.
if you are having cable issues, once you get it fixed, check your grounds (or do it now). when you have a bad ground, often times the cables (gas, clutch) will act as a ground to compensate, significantly shortening their lifespans.
good luck.
SilikonBlu
23
  • Apr 21, 2004
Well, I went out last night and played around with the accelerator pedal and cable at the point where it entered the firewall. Some WD-40 and a little bit of poking around seems to have solved the problem. Weirdly enough, after spraying cable and then working it a few times the pedal response seemed normal. A 45 min test drive showed no indications of the problem.
I just purchased the car this past weekend from the original owner's estate (deceased). The guy was meticulous about taking care of it (always serviced at a Ford dealer - full receipts, bill of sale, etc.) It's obvious that he didn't drive it very hard either, as he only had the 1st clutch replaced in 2002. Maybe the car hadn't seen WOT that often and the cable just needed to be broken in (wishful thinking?)??? I'll keep my eyes on it during the summer - but just wanted to say thanks to everybody who replied!
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
