would 70mm tb help or not?
If you're planning on single turbo and AFR heads, then definately go with the 70mm. having an oversized throttle body will not hurt you performance wise. It won't help if you dont have the supporting performance adders, but with your plans, you'll have the power to use your 70mm to its fullest capabilities.
