Would a 347 stroker swap require a new ECU?
5spd GT said:
Good question...could I run a 331 or 347 without a tune just as I'm doing with my 302 (daily driving it).?
I've seen guys run some pretty mean NA 331's and 347's on the bone stock computer without tuning. I'm sure their setups could benefit a good bit from custom tuning though(powerwise and driveability).
Yeah my 302 runs good with just timing/fp pressure/spark plug gap set...I drive it everyday with little effort:shrug: I'm hoping it will be the same with a 347 for example?
For what it's worth, my brother's 11.1 cr 347 runs fine on the stock computer. :nice:
EDIT: It was a daily driver for a over half of a year at one point w/ no issues at all.
Required = No
Optimal = No
The A9L and most EEC-IV systems are very adaptable, unlike newer OBD II systems. Instead of having set parameters and limits in thier tables the EEC-IV just adjust all it needs to to align the tables. Maby my definitian isn't the same as others but it is true. The only thing is that the computers in our cars are in fact 80's computers, and we know about them. They are slow and limited in their abilities.
So your A9L will work well, but it probally won't run as good as it could. Tuning is very limited unless you add something like a tweecer which manipulates the signals. The way to really go is with a stand-alone unit, which is costly, but is far better.
5spd GT said:
Would it be "harder" for the computer to adjust compared to the 302? Saying you got a 347...or 331?
Well, technically, no. I guess it would really depend on how agressive the combo is, rather than cubic inches. I belive the cam would have more effect than any other. A cam with a lot of overlap will release air into the exaust at lower rpm's which will be detected by the O2's which will make the computer think it's lean, and it will dump fuel.
I'm thinking of keeping my same cam (it is already pretty aggressive) - .560 lift, 224-224 duration. I'm sure it would do fine. I like my brakes as is :)
So maybe it will adapt the same :shrug:
the MAF computer is very adaptive. I have heard of people running 450+hp with it
you could leave it all stock, the worst that would happen is you might run a little dry up top depending on what your heads/ cam is.
some bigger injectors and a matching MAF should set you straight
and of course some PMS tuning on a dyno or at the track would only help. but not nessesary by any means
