well, a few bits of knowledge from the peanut gallery
-first, the alt pulley w/ the UD pulley kit is an "overdrive pulley", it is bigger than stock...
-but to answer your question, it will diminish the performance of the pulleys by leaving the stock alt pulley on it... although you won't run into charging problems (not that I have any at all, just slightly dimmer lights at idle... ) the power results have been dyno proven (by a guy w/ no life, too much money, and time
) and showed by several pulls that w/ the new alt pulley, it completes the system, and gives you some more power (but keep in mind, it's only about 1-3FWHP, very marginal... so, it's all up to you... personally, I ran the new pulley...)
-sorry for the long post, but figured I'd give you what I knew on the subject
