Sleeper5.0 New Member May 31, 2009 11 0 0 Quebec Apr 26, 2010 #1 Apr 26, 2010 #1 My car have AFR strip heads (non-emissions), no air pump, and i want to know if it will run without the egr spacer?
Kdubslugga Active Member Jun 7, 2003 1,515 3 38 Akron, OH Apr 26, 2010 #2 Apr 26, 2010 #2 I would think so, you may have to pull the egr sensor and tuck it away while its plugged in, just to trick the computer. This may or may not throw a check engine light. But i wouldnt see why it wouldnt run!!!
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,260 17,945 224 Massachusetts Apr 26, 2010 #3 Apr 26, 2010 #3 Yes, technically.
speedtrip Member May 22, 2005 93 5 9 Jerkwater, U.S.A Apr 27, 2010 #4 Apr 27, 2010 #4 I think it would run. Youd have to mount throttle bracket somewhere also check cruise control interference.
P phutch11 Member Nov 14, 2005 328 2 18 Apr 27, 2010 #5 Apr 27, 2010 #5 I removed mine and replaced it with a 1/8 inch piece of plate steel cut to match the TB diameter and with a mounting flange for the throttle cable. Easy. Took all of an hour to complete. I don't have cruise, so not sure how that might affect things. Good luck...
