Would someone host my dyno sheet...
98GtRioRed said:
Thanks LByellowstang.
Here we go.....
Pro-M 77 Maf
C&L inlet pipe
Ford Racing Roots style supercharger at 6psi
Ford Racing Shorty Headers
BBK off road H
Mac cat-back
1998 GT
Stock heads
other suspension mods that don't apply here.
Thanks again LByellowstang
Thats some great HP for only running the 6psi pulley and with the level of mods you have. The only thing that looks bad is the A/F ratio. You're running 14:1 up to 4500 rpm's. Thats WAY too lean for a SC'd car, you'll eventually fry a piston. You should really be at or below 12.5:1 all across the RPM band. You'll probably drop down closer to 300rwhp when you adjust the A/F but the motor will live a happy life. Also don't install a 3.4" pulley before you adj the A/F or your motor will probably puke the 1st time you go floor it. Here is the link to my recent dyno. http://www.corral.net/forums/showthread.php?s=&threadid=391737&highlight=d97gt
No it is not tuned. Just the Ford processor that came with the install kit. The program is from Ford direct. I do think the air/fuel seems a little eractic. Should I go for a custom tune or a chip to get it in the 12.5 range?
