The 44/94 codes have nothing to do with the idle.
See the "
Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The
first two posts contain all the updates to the fixes. At last count there were
24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
Codes 44 & 94 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks.
The computer uses the change in the O2 sensor readings to detect operation of the Thermactor control valves. When the dump valve opens, it reduces the O2 readings in the exhaust system. Then it closes the dump valve and the O2 readings increase. By toggling the dump valve (TAB) and switching the diverter valve (TAD) flow from the back of the heads to the air pipe, the computer tests for the 44/94 codes.
Testing the system:
Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect
the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump
the pump's output to the atmosphere or pass it to the next valve.
The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or
to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the
vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes
from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheel well turn the
vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire.
Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to
the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground
necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side
will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the
vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel &
the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum
to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin
32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine
with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after
doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to
ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the
solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38
and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin
38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the
solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power &
ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
See
http://forums.stangnet.com/attachment.php?attachmentid=50636&d=1180923382 for a very nice drawing of the Thermactor Air System (smog pump) plumbing
If you have a catalytic converter H pipe, you need to fix these codes. If you don't, then don't worry about them
