I can't figure this one out......
My buddy put a cobra intake on his motor and started having overheating issues and it was pushing water out the radiator. We figured that it blew a head gasket so he took it to a local mechanic and had it chemical tested. Of course the liquid changed color indicating a blown head gasket. It wasn't a big deal because he was building a new motor to take its place in a few months.
Ok so heres where the problem starts, we put the new motor in this past weekend, fire it up and same thing, it overheats and pushes water out the radiator. He took it back to a local shop and again had it chemical tested, same result, blown head gasket. At that point, he ran a compression test on all cylinders and they ranged from 147 to 152. Common sense tells me to go back to the initial change which was the intake but I don't see how this could cause the problem. Exhaust gases in the cooling system and pushing water out the radiator indicate a blown head gasket completely.....but the compression results don't agree........
Does anyone have any clue what is going on here?
thanks, Larry
thanks, Larry
